jake2077
- Dec 6, 2018
- 106
As the title suggests, I am restoring a 1971 Bronco and decided to drain the 9" rear differential oil. Much to my disappointment, there appeared to be rust INSIDE the diff and even on the ring gear. I cleaned as much as I could but there is obvious pitting and deterioration of the metal. The identification of the gear shows C2AW 4210 W F 1. I found a ring/pinion set on FB marketplace but the part number is slightly different C2AW 4210 F W 3. Does this matter? I know nothing about gearing and ratios etc.. Just looking to make it right and maintain what was there originally.
