plate between 302 and auto tranny
amc78cj7
Ann Arbor, MI
There is a thin stamped steel plate with a lower inspection plate that mounts between a 302 and a C6 automatic tranny. It is required for mounting the starter with an automatic tranny.
We are selling the C6 and replacing with an NP435 manual tranny. Should we keep this plate between the engine and NP435 bellhousing or sell it with the C6?
Thanks.
Hal9000
Flagstaff, AZ
Dunno about the 435, but my stock 3 speed has basically the same thing. If it wasn't there, the FW would be exposed at the bottom half of the engine.
I'm assuming that you need to keep it, or find a MT specific one.
Smokeater11
Auburndale,FL
The piece you are talking about is the dust shield and they are different in an automatic and a standard tranny. The standard tranny dust shield doesn't have the inspection plate piece, it is all one piece and bolts to the bottom of the bell housing. You will have to find a dust shield for a manual transmission so you could send the one you have with the C6. You will also have to have a different starter. The automatic tranny starter has a longer nose on it and it will hit the back of the bellhousing before it even gets remotely tight. Do a goggle image search for manual versus automatic dust shields and starters and you will see what I'm talking about. Sometimes you can get lucky at the junk yard and find a vehicle with the tranny removed but they left the dust shield and you can grab one without having to work too hard. I went through this issue when I put my NP in. I had an auto dust shield and it wouldn't bolt up. I got lucky and Bax had an extra manual one.
Hoppy
Gresham, OR
when i did my np435 I got a new one from Toms Bronco Parts
I think it is called a block plate
amc78cj7
amc78cj7
Ann Arbor, MI
Thanks guys.
In the past on trail Jeeps I have left off the dust shield. That way I can wash debris off the flywheel. The starter on the NP435 will bolt to the bellhousing, right. If so, will I still need this dust shield as a spacer between the block and the tranny or could I just bolt the bellhousing directly to the block?
That block plate properly indexes the starter the correct distance from the crankshaft. For the life of the starter gear, I would use a plate. Also better idea to keep the bellhousing clean to begine with instad of having to hose it out.
