I am putting a zf 5sp to a 351w, since I did this from an automatic is there a thin metal p;ate that goes between there? Is there maybe adust shield or something that mounts separtely?
The block plate is different between auto and stick as I found a while ago. The block plate also is what indexes the starter in the right place so you really should have it. Try and find one for the ZF application and use that. Usually the junkyard sends them off withthe engine, too much work to pull the clutch and flysheel to take off that silly piece of sheetmetal.
