Plate between block and C-4????
crawler73
Getting ready to drop in my motor and working on the last few details. One question I have.....I'm putting a 96 explorer motor with a C-4. I'm assuming I use the flex plate from the 96 and do I still need to installed that plate that goes between the block and the C-4?
Is your torque converter from a '73? If so, you're probably ok, but if not, verify that the bolt pattern is correct between the converter and the flexplate (if you haven't already that is) before you get it all half-way installed.
Finding out they don't like each other is a bummer in the summer indeed!
C
crawler73
Yes, the C-4/converter for from a 73. Ok so use the dowel plate and am I correct in staying with the flex plate off the 96?
Correct. The '96 flexplate will match the balance of the '96 engine. The offset will be correct for the '73 C4 flexplate. The bolt circle on the '73 should be the larger 11.4", the same as the '96. But a lot of Broncos have had parts changed over the years, and the mid C4 years had a smaller bolt circle convertor that won't work (Thus Paul's question about the bolt circle matching)
If you still have the original C4 block plate (dowel plate, starter index plate) I would use that. While the '96 4R70W plate will locate everything necessary there are minor differences on the lower part. The inspection window, the lower part of that plate, that is different between the C4 and the 4R70W. If you use the C4 plate behind the '96 flexplate the cover will fit perfect. If you go lazy and try to keep the newer '96 plate the lower cover will not fit right and you will either give up and not put a cover on or have to spend even more time trying to make a cover work.
A few minutes now will save lots of time later and result in a better finished product.
But if you don't have the original C4 block plate, go ahead and use the 4R70W version. Just be prepared for a little extra work to get the inspection cover right.
C
crawler73
Perfect that's my plan. The 96 block didn't have the dowel plate so I'm taking the one off the 73
