Congrats on getting it squared away. Please tell us what you had to do to it. It both would satisfy our curiosity, and may help someone down the road who finds this thread while trying to do the same thing. Thanks for the update.
Here's a thorough, comprehensive list:
1) Extracted as much fuel as possible from both tanks through filler pipes. Disconnected fuel lines to engine and pressure forced remaining gas from tanks.
2) Replaced spark plugs.
3) Lubricated each cylinder.
4) Let lubricant set, then manually turned engine.
5) Thoroughly cleaned the carburetor.
6) Resealed accelerator pump with new gasket from carb kit.
7) Replaced fuel pump along with 1 section of fuel injection hose at pump.
8) Replaced fuel filter.
9) Replaced drive belts.
10) Replaced battery, cleaned terminals.
11) Replaced battery cables and installed new ends along with a negative disconnect (not a bad idea for a truck that isn't a daily driver.)
12) Replaced the air filter.
* While attempting to winch the Bronco onto the flatbed to have it towed to the shop, the left rear wheel was completely locked up, so the brake system had to be carefully inspected. We found gear oil on the left rear shoes due to leaking axle seal.
13) Removed left rear axle, replaced seal and cleaned gear oil as best as possible from brake assembly and shoes.
14) Clean and adjusted rear brakes.
15) Replaced front lower cracked brake hoses attached to calipers. Cleaned all fittings.
16) Brake fluid flush. Drained, flushed, filled and bled the brake hydraulic system.
17) Cleaned out master cylinder of dirt and debris.
18) Lube and oil change: Drained and refilled engine oil, replace oil filter, lubed fittings, filled all fluids to proper levels, inspected tires.
19) A few of the additives, conditioners included: Octane booster, Stabil (fuel stabilizer) G2P fuel system cleaner.
20) Checked all steering for possible damage or wear. Performed a front end alignment.
*The truck was in dire need of tires, so I put a new set of BF Goodrich's BFG 235/75R15.
That's about it. Drove it for an hour, surface streets first to check/settle the system then onto the freeway for a good half hour before getting it smogged, where it passed with flying colors.
