Poor panel clips to remove inside door pael
Mtgrizzlymn
I installed new panels in December and new clips, now I need to get inside door. What is the best way to remove these without harming the panel they went in very tight when I installed them
Sent from my iPad using Tapatalk
72Sport
I got a tool at my local auto parts. The tool looks like mixture of a screwdriver and a claw hammer. Instead of a blade on the end it looks like the nail pulling part of a claw hammer. I would wrap the lower part of the shaft with tape so it doesn't scratch your paint. The claw fits between the panel and the door. The claw puts pressure on the inside of the panel so you don't tear clip out of the panel.
half cab
Guru Bronco
Harbor Freight has a cheap set of theses tools that work well. Also when you put them back this time put a dab of lubricant on each clip.
tirewater
San Francisco Bay Area
I'll just add, whatever tool you get, try to get a plastic one. The metal ones can easily scratch your door if you're not careful. The scratches may not be visible, but still. :)
Mtgrizzlymn
Mtgrizzlymn
Had some plastic tools from harbor freight that worked good and I had them in my tool box even better.
