jesus888
I'm not sure if we have a bad ground on the truck or not. HOW can I figure it out?
This came about after a couple of things started happening...
First off, in order to check the EFI codes that the truck was throwing, we plugged in the tester and it just wasnt' reading properly... when we called the mfg of the tester, they suggested that the ECU may not be grounded as well as it needs to be... is there a way to test this, and are there any tell-tail signs?
Secondly, we're having an issue with our fuel gauge... not getting proper readings. We are certain that it's the correct gauge (ohm range) however when we called Autometer, one of their questions was whether the gauge had its own ground or if it was a a shared ground... it's a shared ground so he suggested that we give it its own ground because "just because you complete the circuit (with the test light) that doesn't mean it's a good ground, which could be causing your problem"
Thanks!
Thanks!
