I would like to purchase one of these tanks but I am unsure what to order as I do not know much about anything other than I love my old bronco.
That's good enough! Ok, well not quite of course, but it's a great place to start from.
And welcome to classicbroncos too by the way. I see you've been here for a few months already, but still new enough to welcome.
I have the original dual tank set-up and am currently missing the aux tank, but would like to put it back in at some point.
Should not cause any issues. Can be plumbed just like they had from the factory with dual tanks, just some new hoses from different points than stock is all.
But I would seriously consider using an electric tank selector valve when you do the install, rather than keeping the old (but retro-cool) manual valve under the seat.
I am not planning on EFI but may do it in the future so I willing to pay up front for the flexibility. Is this workable?
Definitely. I think.
I'm sure they'll tell you one way or the other, but if the tanks are different enough, just order the one for EFI but without the pump so you can simply use the standard pickup tube. Then you're ready to go EFI with an internal pump down the road.
If for some reason the two tanks are different enough, you could opt for the external pump when it's time for the conversion.
But hopefully it's not a big deal.
I will have a 1" BL and am planning on moving my axle back 1" so I would not want to experience any clearance issues down the line.
The 1" body lift is what you need to know for sure now. That way they can set up the mounts for it ahead of time, or can leave them off for you to weld on after the fact. Most will just opt to have Aero pre-mount the brackets, but at the specific height.
I will say though, that with a mass buy, make SURE that your desired height is clearly spelled out, and check when it arrives to make sure. I requested one with loose mounts and they welded them on for a 2" body lift instead!
So I get to use spacers...
I can't say with 100% certainty, but I doubt that your 1" axle shift is going to interfere with any part of the tank.
I will do the skid plate for the extra protection.
Good call if you're ever going to take it off-road. Most newer Bronco owners do not have that intention however, so if your wheeling is going to be minimal or non-existant, then maybe you don't need to spend the money either.
But when in doubt, spring for it. I did and would not do it any other way.
So my question to everyone is what size tank and options would work best for my thoughts? Am I missing any other things?
Unless ground clearance and/or looks are your primary goals, then go for the full 23 gallons. No need to short-change yourself on that score.
The difference in height is pretty minimal too, so the whole "appearance" thing is not an issue for most.
Some just don't like seeing gas tanks, so I brought it up for discussion. I would buy a slightly smaller one if I had to do it again, but entirely for ground clearance as I still plan to bash mine off-road in the rocky sierras.
Every inch counts there, even though I've run a 23 gallon NWMP tank for 20 years and over the Rubicon and other trails many times. It only had a small dent or two, but with dual tanks I don't mind losing just a smidge of capacity.
I'd probably not go less than 20 gallons though, as max gas is still a bigger benefit to an EB than most other aspects.
All personal preference and intended use at that point.
