That's what I was hoping. I grabbed a wrench to see if it was loose....it wasn't. Checked to see if I could loosen it ...Thor must of put it on...I've seen the top leak before. Can't remember if that is a gasket or O-ring.
Don't touch the center nut/adjuster, too often people try to adjust this thinking it is for the play in the box and end up putting too much preload in the box and then you will need a rebuild. You can take the top off and put it back on without touching that adjuster.
I'm gonna get my wife to try....
