Prepping Engine Block for New Headgaskets
MerganserMaster
I have now removed both heads from my 1975 Bronco 302 V8 and want to start on the surface preparation while I wait for my gaskets to come in the mail. How do I go about removing all of the "gunk" without it all falling into the cylinders? I have thought about stuffing them with shop towels, would that work? Also should I clean the top of the pistons themselves as it appears there is some carbon buildup, and if so what should I use to clean it? I do plan on honing the cylinders as there is a fine ring of "gunk" towards the top of them. Below is a photo of the block in question.
https://flic.kr/p/2pnHfBP
Wild horse 75
BC
I would just scrape off the gasket material. Put a shop towel or two in all the cylinders to help with clean up. Just use some card cleaner to clean the tops of the pistons and cylinder walls. I wouldn’t hone anything as you will just introduce so many fine shavings you’ll do more harm than good. Use compressed air to help shoot any remaining crap trapped on the top ring. Just be careful when you are blowing it out that you don’t hit a water passage or you'll be cleaning antifreeze off everything.
I would pass in the honing the assembled engine. It is impossible to get the grit out of the engine with the pistons still installed.
To clean the top of the bores and the top of the pistons, wire wheel. Carbon is pretty soft and a little loose inside the engine isn't that bad. Grit from honing is way worse.
Don't bother changing the oil right away. Get the engine together, run it once and warm it up. Now change the oil while warm. That way you can clean out all the junk that gets in the engine despite your best efforts to keep it out.
Double66
I always use shop rags in the cylinders and cover up the valley really good with rags to prevent debris from getting into any passages. I also use Scotch Brite Roloc bristle discs and they do an amazing job removing all the old material without gouging the surfaces and you can get a lot of use out of them. After that clean up the surfaces good with some brake cleaner and a clean rag. For the top of the pistons you can use the discs if you're careful but I have used brake cleaner and a regular scotch Brite pad like you use in the kitchen with great results for carbon removal.
ba123
CA
+1 on not honing. You get nothing good out of that if you aren't replacing your rings and you risk messing up your cylinders.
To hone the cylinders, you must pull the pistons and rods out first. No way around that. With the lip at the top, there is a tool to remove that lip.
With fresh honed cylinders, time for new rings. When you pull the rods, the bearings won't look that great. Now you are doing bearings as well. All that work and not replacing the timing chain?
You are doing a rebuild if there is a hone involved. Besides you pretty much have to in order to get all the grit out of the inside of the engine anyway.
And if you thought the rod bearings were looking a little thin, the cam bearings are going to be worse.
ba123
CA
so well said.
