Prepping floor pan support channels??
kuch68
Waterford, MI
Just about ready to weld in the new floor pans, and I am wondering what I should do to the inside of the support channels since I won't be able to get to them after welding the floor back in. I have weldable primer, is that good enough? Or should I spray it with something more durable that will stand up to the welding on the flanges of the support channels? Is there such a thing?
thanks
hd03sporty
Tucson AZ
when i did mine i found 30+ years of dirt and some rust flake I live in AZ so the rust was'nt that bad hooked up a stiff wire wheel to the grinder got all the loose stuff off and then coated with POR-15 before i welded the pans back in, then did some spot coating with the POR-15 on the welds underneath and had the tub sprayed in rhino lining......
Blue71
I did pretty much the same. After cleaning them and smoothing them up with a grinder. I sprayed a them with 3M weld through primer. I put POR 15 on the bottom channel and walls of the support braces. After preparing my pans to go in, the last thing I did was POR 15 the bottom of my floor pans all over , except where I was going to weld. This saved me a lot of time underneath trying to POR 15 the bottoms. I put a seam sealer on the seams on the top and underneath. Then POR 15'd them after it dried a day or so later. Looks clean.
Good Luck,
Blue71
