i have just set the edelbrock intake on a 351 and it sits 10" from the highest point on the timing cover to the top of the throttle body without the air cleaner . measuring an installed 302 with the explorer intake from the top of the timing cover to the top is the same 10". as close as i can tell the 302 has 1.5 inches clearance to the hoods center support channel . , didnt really want to use a scoop but i dont think there's any way an air cleaner will fit as is.
i had posted before on this and thought i had no problems but the point of reference as the timing cover is more accurate as they are interchangeable, 302/351, previously i had used the valley height and that is where they differ. Until i install the 351 i really dont know what the final number will be the way things work out.
A 302 will give about an inch more clearance and if the hood's center support was moved one might find an air cleaner to fit.
If anyone has another solution i would appreciate it. Thanks..
