At the Earls store they had two sizes of reusable fittings and hose but still -6 fittings on the ends thus the limiting factor in flow. Should I use the larger fittings with the larger ID hose for the pressure side or should I limit back pressure and use them on the return side? Does it even matter? I'm running hydroboost and a ram assist if that factors in.
Thanks,
Jon
Thanks,
Jon
