Well I hope everyone had a great holidays. I sure enjoyed a full 12 days away, spending time at my daughter's home in Erie CO. Even though I was away. We (my son inlaw Matt and I) managed to make a few parts for my build. Matt has a 3D printer, so we experimented printing a few things.
The Lock and Load center console I have. Has a cup holder, similar to the Tuffy console. Which I don't really like. So using CAD I designed a cup holder insert to fit inside the cup holder housing. It looks like it will work pretty well.
However I missed a couple dimensions. Making it to wide and the center location of the cups are about a 1/16" off location. So I had to mill some off of both sides of the width. To fit it inside of the housing. So we will have to print another one. You will notice the orange colored inserts in the inside of the cups. We made a "D" shaped insert with a retaining key. Out of a flexible plastic (I think it was called TPU? Plastic) it is flexible like rubber.
To insert the orange cup cushions. We printed from the base up until we reached the top of the keyways for the inserts. Pausing the printer so we could insert the cushions. Then restarting it to encapsulate the inserts. Looking closer at the outside and inside of the cups. You can see a couple start stop lines in the printing process. The lower one was from running out of plastic and reloading another spool. And the other one from pausing the program for the insert install. One other feature I incorporated in the design. Was drain holes and a catch basin for condensation. Now that I had to narrow up the cup holder to fit the housing. I'm going to eliminate this feature.
Next up I am working on a design for a transmission tunnel cover for the twin sticks. Here is sneak peak picture of the prototype so far.
Sandwiched between to slotted pieces of polycarbonate plastic. Are two sliding pieces of 16 gauge stainless steel. With 1/2" ID rubber grommets. The SS plates slide independently from each other, inside the plastic.
The whole assembly, will be sandwiched inside of two, 1/4" thick plates of Aluminum. The aluminum plates will have milled in pockets. To accept the plastic assembly. The pockets will be wider than the plastic assembly. To allow some side to side motion of the twin sticks. I still need to make the aluminum plate housing. So more on this project later.
If the twin stick cover works out. It will be incorporated into a tunnel console that is in early concept.
Have a great weekend.
