crawln68
- Oct 8, 2004
- 3,045
68 Broncoholic said:What lift is that 3.5"?
How much further back is the 205 using the 203 doubler?
What I'm getting at is on my 205 I had to lower it 2" below the frame so the front driveline wouldn't bind at full suspension drop. I run a wristed radius arm and get lots of flex so its a concern. You will to with the cage arms.
I like the side mount for the 205 you built. I have about 1/4" of space between that area of the t-case and the frame. I was unable to make a mount with 1/4" of space. Now that you raised yours above it gives me some ideas for more t-case support. How about the rear driveline, any bind there? If I raise mine I'll have to run those Tom Woods offset u-joints or get a special set up from high angle driveline for more drop without bind.
Nice job by the way, I remember when mine looked that purty.
I have a 5.5 lift and 2 inch body lift. I would say that my 205 is back about 10 inches versus not having the 203 in there. The 205 is right where the Cage arms mount to the frame. The whole 435/203/205 set up is about 1 inch longer than my stock 3 speed/intermediate housing/D20 was. I hear you on the front drive shaft bind at full droop. I don't have my drive shafts in yet but I think I will be okay because of the HPD44 that I'm running. If it does bind, I'll have to go with the Tom Woods or High Angle shafts.
I have a feeling that it's not going to stay very purty for very long. ;D
