Project grocery getter
P
ponyracer
Crestview, Fl, 32539
Here's a few pics:
Finished my pass side front wheel well area
Front brake lines, ran them through the engine mount.
Got the hydroboost on
fordguy
which calipers and rotors did you use? do you have an e-brake?
P
ponyracer
Here's some shots of what I've been doing today.
Still having problems with the HB, CAN'T seem to get the air out of the system, steers hard and growls when you hit the brakes.
P
ponyracer
Ram mat audio, should quiet the ride down a good bit. I welded washers to the floor for support where the seat bolts go through it.
Anyone think I should weld the top on solid? I'll prob never remove it anyway. I'm sick of the water leaks and looking at it.
camomog
Reno, Nv.
You could get the tape from a RV place that goes under campers, its about 1/8" thick and would seal it and still give the option to remove it and it's cheap.
cobralee
Northwestern OK
Still loving the buildup man, thanks for the posts.
IMO I wouldn't weld the top shut even if you plan to never take it off and even if you plan to "never" sell it. I think it would be a MUCH better selling point for the Bronco in the future if the top is still removable just in case something comes up and you do have to sell it. Welding is much more "permanent".
Steve83
Welding doesn't insure no leaks - it just insures that, if there IS a leak, it'll be a nightmare to fix. But if you prep it REALLY thoroughly & apply plenty of seam-sealer in strategic locations, you should be OK welding it down. I'd test-fit it at least a dozen times to check the seams & door seals before the first tack weld.
P
ponyracer
I'm on the fence about it, I may try the weather strip route first and see what happens.
Well I got the HB working, drum/drum/manual to disc/drum manual to disc/disc hydroboost, OMFG what a diff. Still trying to scrape off the skin I left smeared on the windshield the first time I hit the whoooaaaaaa pedal.
P
ponyracer
Got some pics:
She's a little high in the front, I'm going to add a winch and heavy bumper so It'll prob equal out, if not I'll block the rear to match.
Fuel tanks done, not real happy with it but it'll work for now.
Rear shocks mounted.
Full width views, 35x12.50's on 3.5 bs 8" wheels
Clearance shot, ya I know it needs paint!!
Need to raise my trac bar to the upper mount
P
ponyracer
Thinking of looking for an extra cab truck to get the back of the cab from. Cut the A pillars and below the side glass and rear glass. Box it in and weld it on or make it removeable. Prob be easier than trying to mod my current rusty modded junk top. Anyone have any ideas? Ranger extra cab? F150 would be to wide=custom rear glass or cut down rear glass=$$$.
Looks like I'm going to the j/y with a saws all and a tape measure....
73stallion
Eugene, OR
i like it. but i keep wanting to ask you, are you only gonna run 3 leafs in the rear? concerned any about axle wrap?
P
ponyracer
Not sure yet, there 3" wide and came from a 2000 e250 van. 8 lug wheels, d60 rear, the funny thing is that I only took out the flat bottom overload. Not sure what the load cap of the van was but it was the extended panel van so It must have been alot. I'm going to drive it on the street and get it in the dirt and do some testing.
englewoodcowboy
Lick Creek Restorations
I think you will be fine... more than likey to pull one more leaf if she is too stiff. Them vans were heavy and designed to carry alot.
73stallion
Eugene, OR
the more i see these, the more i think ford should have built a longer bronco body! kinda want to extend mine now.
P
ponyracer
I'm going to start a petition for the aftermarket glass tub makers to build a stretched version. I like mine but I can hear it rusting from inside the house lol.
73stallion
Eugene, OR
don't remind me, you're probably hearing mine rust all the way from here in cali....
