Project "BOB - Big Orange Bronco" Wheeling pics addded
SC74
SC74
Thanks for the compliments! Here is another picture that shows the scoop better. Got the tailgate put back together and on the Bronco tonight. Gearing up for wiring this weekend - using Ryans EFI harness and 4wheeljunkies body harness.
NGABronco
N. GA now South Carolina
Hey Robert, give me a shout, I may have a set of "Ranger" letters to go on that "sweet looking grille"!!!
Did Keith mention the "Swamp Monster"???
See ya';D ;D ;D
SC74
SC74
See ya';D ;D ;D
Emblems on the grill would be awesome ;D
I did see "Swamp Monster" and have had fun forwarding it on to others.
We got some work done it today but no pics. Lots of small misc but time consuming stuff done.
744x4
Taylors,SC
The spraying of the paint was a little learning curve as the nozzle that came with the HF HVLP gun was a 1.4 and should be used for clear coat not paint so the paint had to be thinned down to get it to spray and not glob.The pressure had to be jacked up way past the indicated 43 PSI that was stamped on the gun.(100 psi) is what I ran it as so so much for the benifits of the HVLP part.I believe the proper nozzle is 1.8.The compressor is important also as it must push lots of air without making moisture.Mine is a 60 gallon IR that puts out 13 cfm @ 90 psi.Ben all the Kubota Orange paint you want can be had @ Tractor supply as I only used 1 qt for the truck after 4 passes on most panels.
BTW there is a difference in Kubota Orange and "New" Kubota Orange that makes itself known once side by side.
744x4
Taylors,SC
The letters wont work unless I drill lots of holes to make them work as it is not a Sport grill.It is another wierd one as it is a Explorer package but not a Sport or Ranger model so there arent any holes in the grill.This is the 3rd wierd one in a row and I am done trying to figure out WTF Ford was doing.
Jacksoon
Newbie
Hey Keith, you know where I might find a good Monte Carlo ???? Maybe one with a few dents. LOL ;D
SC74
SC74
Are the batteries in the camera dead or are you being lazy????%) %)
BOTH! j/k... here are a few pics of the beginning of the wiring. We plan on working on wiring all day Saturday but I'm sure that a few trips to the parts store and radio shack will slow us down.
SC74
SC74
The computer is mounted under the cowl - high and out of the way. It's held by an angle that's riveted to the firewall and a swing-arm so that it can be removed without having to take the dash out.
SC74
SC74
Here's a shot of the Derale cooler/fan combo that I'm going to use for tranny cooler. It will mount in front of the radiator on this bracket that connects to the tube support. We still have to do similar for the PS cooler - using a Superduty cooler for that.
SC74
SC74
Got a lot of wiring done today. Took lots of pics but left my camera at Keith's house. It's very very clean so far - even fished the rear harness through the frame. Hoping to wrap it up most of the wiring tomorrow.
Also installed the WH ceramic shorty headers. These are NICE!!! Pics to come tomorrow when I get my camera.
SC74
SC74
New Headers
Here are a couple pics of the new ceramic coated WH shorties ;D
SC74
SC74
Keith got a lot more wiring done today. Notice how I say "Keith" got the wiring done - he won't let me touch the wiring - I don't blame him. So I worked on other nic nacs like cutting and welding the steering column shaft and quick disconnect nut, painting odds and ends, working on the fuel lines and fuel cell, etc. The wiring is ALMOST done - another day and it'll be 100%.
The RJM harness leaves the relays and fuse box in the engine compartment but we have no room to mount them in a place that will stay clean with the open front clip and no inner fenders. We're going to have to unwrap some of Ryan's loom and re-route some wires so that we can drill another hole in the firewall and install the relays and fuse panel in the glove box. That will take longer than finishing the harness, but they will out of harms way.
The old Master Cylinder hole made a good place to route wires through the fire wall so we made an aluminum cover with 4 separate grommets.
SC74
SC74
Here are a few shots of how we routed the wiring to the rear. It goes into the frame rail just past the middle body mount. We have a tee that comes out mid-way that crosses under the body to feed power to the fuel pumps and the fuel sending unit wiring. The rest of the rear harness stays in the frame rail and exits at the frame rail where the trailer light connector is. The balance of the harness will plug into that trailer connector when I install rear lights etc. I really like this part of the 4wheel Junky harness.
SC74
SC74
Here are 2 pics that show the gauge lights off and on. We also re-used the stock "brake" dash light as the engine trouble light.
