PS conversion, I’m getting one of these. ;)
ared77
Interesting! How much do they sell for?
ssray
ssray
South Central NE
Steve, When I get my Bronco converted to mid engine independent suspension I’ll be ready to install.
ared77, I didn’t see anything about price. Sounds like they build for a lot of manufacturers and I don’t think I could afford it even if it did get to the aftermarket segment.
Interesting technology.. I would think that they could be hard to steer if the electric portion failed unless there’s a clutch in there for that scenario. I have heard that electric is expensive to fix.
Scott
jckkys
Small front wheel drive SUVs with over stuffed engine compartments, are the reason electric assist power steering was developed. I have one in an Escort. They require rack and pinion steering that limits suspension travel. The larger issue is lack of reliability and a horrible safety record. The resulting lawsuits and recalls make these points emphatically. Some like the 2008- 2014 Escorts suddenly fail then pull to one side. Many of the worst accidents were the result. The earlier Escorts also fail suddenly and without warning leaving the driver with arm-strong power steering. Repairing them is super expensive for those that survive the failure. The local Ford dealer needs 2400 bucks and several small shops won't touch it. Putting this in an EB is the worst idea I can think of.
Timmy390
Conway, AR
Not Bronco but there are several Samurai's running around with junkyard conversion EPS using the column mounted motor style system. No Rack and pinion. It uses the factory steering box on the Sam
I looked at it.....might be a something I do down the road to my Sam
Tim
jckkys
The OP was referring to the Nexteer system, not potential systems of a different design. The Nexteer system IS a rack and pinion add on just like the Escorts and likely they manufacture the Escort system that is a huge safety hazard. I would never buy another vehicle with this system. Do the research. I'm sure the big 3 car and light truck makers have known about this and thus continue to use engine powered hydraulic power steering where there's room for it.
ssray
ssray
South Central NE
FWIW I had a wink and a Lol in the first post and no I’m not building a mid engine Bronco either. :) Where would I put the passengers....front rumble seat?
I have a relative with a 66 mustang that would like power steering and have seen the add-on electric PS that goes in the steering column but with what jckkys has mentioned sounds like electric may not be mature yet.
Scott
jckkys
Oddly few do a search to see the many recalls and law suits. I wish I had researched before buying one of these.
EPB72
Pleasant Hill, CA
At our shop we have installed on a customers 67 mustang gt 390. the steering column mounted electric power assisted steering it works very well with no issues 5 or so years running and is a daily driver..that being said I wouldn't put it on a/my bronco see zero benefit on a off road /crawler..
as far as mature for electric steering well every Prius on the road has electric assisted steering ,f150 from about 2010 have electric assisted steering racks including raptors,,many if not most of these vehicle's have 100k plus miles without faults..
ssray
ssray
South Central NE
"I have a relative with a 66 mustang that would like power steering and have seen the add-on electric PS that goes in the steering column but with what jckkys has mentioned sounds like electric may not be mature yet."
Thanks for the info!!! I've seen some comments about them being just a bit shy of conventional PS but very worthwhile. I've just not been sure about how they act if the electric motor fails or worst case locks up. My relative already had a close call last summer when she lost the brakes on her 66. Had a leak and now it's got new hoses, wheel cylinders and master. BTW, I had a 66 Fairlane GT 315 HP in HS that would really haul, but the gas milage really sucked! My brother ended up with it when I bought the Bronco in 73. Bit of a step down in performance! LOL
Scott
