Since I removed the lines a few years ago to go with a remote cooler with thermostatically controlled fan, the upper and lower radiator connections for the automatic transmission hard lines on my stock brass radiator are capped. Now that I would like to reconnect that line and bring the radiator back into the transmission cooling circuit, I can't remember what the fittings looked like.
What I don't recall is what the fittings should be on the radiator. There are two plugged fittings on the radiator now. Do I need an adapter to go from the threads in the radiator to the nut and flare on the hard lines at the radiator end? I honestly don't recall what the original fittings looked like! I got the stock cooler lines, but what are the fittings on the radiator?
