Question for lined tubs...
trailpsycho
ALot of people have had a significant portion of their tubs lined with Line-X, Speedliner, Rhino, Durabak or other. I know several people did their engine compartment, inner fenders, firewall, inside underneath, etc. I am planning on coating just about everything but the major panels...I am looking for problem areas that may provide fitment issues later once the fenders, hood, tailgate, doors, etc are re-attached. Specifically, on the hood to cowl mount should that surface be taped off?...mine already had a shim or two in there, so it could probably take the thickness, but I dont mind taping this area. Another example is on the top of the inner front fenders where the frotn fender bolts down using the clips...do the clips become a problem, does the thickness of the liner cause fender door alignment issues? Another area would be the door jambs where the lift-off hinges bolt to the door post, should these be taped offwith the hinges removed ? The liner may make it tought to adjust the door or casue fitment issues??.. OR should the hinges be removed for media blasting and then bolted back on (fitted with the door) and then line-x over the hinge with the hinge-post taped?? What about the inside of doors?
Current plan is to media (soda) blast entire tub completely disassembled, epoxy primer EVERYTHING, seam seal, paint major panels, rear quarters, hood, windshield frame, tailgate, then coat inside/underneath/inner fenders, rockers/over the bedrail/firewall, inside of tailgate, inside door panels, inside of doors(?). What are the thoughts of those who have done this already? Am I forgetting anything?
Not looking to bust anyone's balls or bring up any bad memories, but I would love to learn from others' misfortunes or miscalculations as well as their successes, planning and experience. What didnt work as planned? Whats a better way? Thanks for any and all comments or experiences with this process. Alot going on over the next coupleof months that I will start on a separate thread.
Thanks for your time and attention.
John/Trailpsycho
PS
Sebastopol, CA
You hit most of the areas I had trouble with during reassembly. I did LineX inside my tub, the engine bay, including the firewall, and the full underside. The engine bay (core support, wheel tubs and firewall) was sprayed body color as we can't get colored LineX in California. The LineX was mostly a big pain in the rear during reassembly - the build was anywhere from 1/4" - 1/2" and many bolts in my new stainless hardware kit ended up being too short. Hmmm, how did that happen.
If I were to do it over again I'd still do the LineX (but from a different vender) on the inside and underside, but I'd spray POR15 in the engine bay and core support and topcoat it with body color.
The LineX had to cut/ground away from the fender and grill mounting points and I'm not sure that it would possible to mask everything to make reassembly totally painless. I didn't LineX the door jambs so the hinges weren't a big deal for me.
I thought about coating the inside of the doors but instead sprayed them with POR15, it's much easier to work with and a darn sight cheaper than LineX. Also, the vender that did my LineX turned out to be very difficult to deal with, great product but terrible service. It's just a franchise anyway.
The reassembly nightmares are beginning to fade and in 20 years when I don't have any rust they'll be completely gone.
bmc69
My local Line-X guy is especially good at applying the stuff in unusual or difficult situations..and is a good friend to boot. So I guess I'm lucky there. The masking 'tape' system that Line-X uses is very special in that it has a 'pull wire' along the edge of the tape boundary that cuts the cured urethane cleanly and allows what is on the masking side of the mess to simply be ripped back off nice and clean. I work closely with my Line-X guy to define all the areas that need to be masked but all the masking is done with their special masking product. So...good relations/communication with yr Line-X guy are a must. Where I've missed protecting holes or misjudged where edges and masked areas needed to be..the stuff is hatefull to cut/trim/sand or otherwise remove from where you don't want it to be..
trailpsycho
trailpsycho
BMC69-
I hear you on all that...it will be hard to leave it there and not hover. This guy is pretty professional though and has a very successful shop...there are a few other dealers in town but he has been around the longest and I havent heard anything bad about them (Millenium Linings). He has done alot of unique stuff, so I feel pretty--moderately good about that. I am going to try and have everything that isnt a "necessary" hole already buttoned up or a bolt in it...that way if there is a hole they know they need to tape/protect it. I was thinking about installing nutserts for the bed rails, should I do it before or after the line-X...common sense tells me before, but I havent used them and am not sure how much of a lip they have when they crimp/clamp/interlock. Thanks for the feedback; keep it coming.
John
SACHEM
Back From the Dead
I have Rhino and it is way too thick on the tailgate section. This is only a problem because of the STC tailgate channel. Basicly it makes it near impossible to get the back window out of the channel. I tried shimming it and it helped but I still have to put my back window in with a really blunt common screwdriver.
