question ref reinstalling the 4wd selector (grease cap)
taz7nads
Iowa Park, TX
i have finally gotten a new bearing lock nut (had to go to 2 different places to get them, and one is wrong size) and got everything back together except the selector/grease cap. is there a secret to placement so that it will work correctly, as opposed to trial and error with the six different positions?
blubuckaroo
Grease Monkey
Ridgefield WA
With the lowest point of the cams on the knob, resting against the follower fingers, the hub will be locked. When you turn the knob to "free," The cam will depress the follower against the hub, unlocking it and compressing the spring.
T
taz7nads
Iowa Park, TX
okay, thanks. i've never messed with 4wd, or even drum brakes. but after having torn these down and reassembled, and with TONS of help from here, i think i've figured out how the 4wd works. thanks again.
Rustytruck
The actual locking hub actuator goes through the 6 hole threaded mount that is held in place by the large snap ring. The actuator sits behind the plastic knob and will only fit properly on the deepest part of the cam on the back side of the knob. Then you rotate the outer retaining housing (the Chrome Part) until the bolt holes line up with the threaded mounting holes. If done this way it is the easiest to do and the hub is unlocked. Trying to line it up just any ol place you fight the hub spring while screwing in the 6 allen screws.
T
taz7nads
Iowa Park, TX
I got t back in place with the advice above. Selector turns like it seems it should; will check and see if it engages correctly after I get the brakes bled. Now all I've got to do is find a correct sized nut for the other side. Nobody had 2; Parts Plus (80 miles away) had one that is correct; the one from NAPA (20 miles) is wrong. OD is good, but the ID is too small and the "pin" is out of place. The new ones had a pin that measured .075 and .090 long; the ones on it measured .045 and .025 long, so I figure they need to be replaced
SHX669
Only for future info ; the Bronco vendors sell Spindle nut kits . At least that what i think youre looking for $15 a side from Wild Horses I think.
Steve83
The exact OD of the pin isn't critical, as long as it's small enough to fit through the hole in the locking ring. The pin length & stickout aren't critical, either; as long as it sticks out at least the thickness of the locking ring. When the 2nd nut is installed, it will press the pin in to the correct stickout. If it doesn't stick out enough, use a small drift & hammer to push it out farther.
This diagram shows 3 types of early hub lock:
