Quick removal rear seats
g8rb8t
Hey guys - I've seen this covered in a few threads, but have a few follow-up questions:
I'm researching using something from http://www.macscustomtiedowns.com/ to mount my stock rear seat.
My questions are how would you mount this to the floor? I'm concerned with safety, thinking grade 8 bolts, however what about underneath the truck? It appears my truck doesn't have the welded in rear seat nuts to the floorpan in the rear, currently the seat is just bolted through the floor.
That said, I want to do something different and ensure safety while allowing removal/quick disconnect of the stock seat.
Also, these don't appear to be grade 8/seat mounting safe http://www.macscustomtiedowns.com/product/m10-threaded-stud/VersaTie-Fittings
Thoughts? Are the Macs custom tie downs made for seat mounting? Could use some input please :)
Ford didn't make the floor mount for the rear seat very safe if your going to look at mounting bolt strength. But you have to consider that then the real strength is in the hardware holding the seat belts which carry all the load in an accident. There they are more than strong enough and have been tested by the factory. If you don't wear your seat belt it doesn't matter if the seat stays in place or not.
chuzie
What about keeping the seat intact during an accident without a passenger? Don't want it to go flying around. That track will be enough to keep the seat secure and you can get enough hardware on it to spread the load across the floor so it doesn't rip out. I think my only beef would be the rattling when no one is in it. Those systems are great but if there is no tension on them, they make a lot of noise.
metal1
hidesert ,socal
I set up my rear seat to use 1/2 hood pins to hold it in. I threaded the pins in to the floor and drilled the pins for a new hitch pin location so it held it tight to the floor. I used the carpet as a cushion so no rattling when nothing on it or in it ,my seat fits both looking forward of facing rearward .I also made a rack to fit the same mounts for holding gear ;)
pcf_mark
I assume your seat belts are anchored to the floor? If they are anchored to the seat the hitch pins are going to see incredible stresses during an accident and may fail.
My conundrum is quick removal and I want the seat belts to go with the seat not laying on the floor in the back.
