BPerry
Newbie
- Dec 7, 2021
- 168
So, without the support group I have likely made a slew of bad decisions... Lol
This will be a long one... Gotta catch up!!
Particulars = 351W, New 4 core rad "not Aluminum", new shroud, PO's 16" flex fan, PO's 16" pusher elec fan (PO has cut the lower horizonal support to accommodate this).
Temp likes to sit between 203-208 while driving at 0 grade (which is fine), starts climbing with any fluctuation in grade or pull on the motor "mind you with 5.13's she is running 2850 ish RPM's at 55mph", bring her down to 2400-2500 and that's where she wants to be. This is why I'm moving to 3.89's or 4.11's, that rpm range seems to be the sweet spot.
All good right, change the gears and be a happy camper! Nope, I live in Arkansas, it gets hot... I understand a stationary rig is going to warm up (especially with the motor is locked up in a tin can with no room to put a toothpick in), but I have to account for this somehow right! So, stationary she just climbs until I'm in motion, I know this is going to happen; I just want to do what I can...
Before I go into the below, let me say! I do NOT like cutting crap off.....
I acquired a new 6 blade 17" fixed fan in plans to ditch the flex fan and keep the pusher fan. Nope, needs a 1.5" spacer to clear the A/C pulley and this puts lower blade rotation all up in the radiator.
So, fling the new fan and go to a shrouded 2 speed elec puller fan! "No" I did not account for the alignment nipple. I need 4" of clearance with the fan mounted externally and 3.5" if I mount the electric fan inside the shroud (this will take some fab work, but I have that figured out). Again, Nope; I've laid under the thing for two nights just looking and thinking....
Here is what I'm gonna do, so ya'll tell me if I'm about to make a mistake!!
Back to the fixed fan, Cut off most of the inside upper radiator support channel (this will allow for the angle change). Cut off what is left of the lower horizonal radiator support (this would include the lower radiator mounts). I already have fabricated 2 pieces of 4" angle iron 6" long, planning on mounting these to the Frame using existing factory holes. Reusing the factory lower mounts with the new brackets attached to the Frame.
In doing this all measurements will work and the rad actually should be in angle alignment with the motor.... Still leaving room up front for the later date A/C install or two small pusher fans if need be!
AM I making a mistake with the Frame mount????
Glad we are back up and running, happy Friday good people!!
BP
BP
