BPerry
Newbie
- Dec 7, 2021
- 168
The block is an 89, I have no idea on the build date. It was built by RHS out of Memphis, many moons ago it was a reputable builder.What is the age of the engine? Age of water pump? Just curious in the way of adding more details.
When mine was almost all stock (engine bone stock, Bronco lightly modified) it would run all day long at thermostat temp. When I was either on a tight technical trail, or the highway for more than a half an hour or so at 70mph (at 3,000 to 3,500 rpm level just above where yours starts to run hotter it sounds like?), it would creep up 20-25 degrees. Those were the only two times.
Never really found out what would do it, but it never really hurt anything either, since it did not go higher. It did not seem to be cavitation in the pump, but it did get more consistent and creep up over a narrower range after I installed an early Flowkooler water pump.
It could easily have been airflow, being that both situations (low speed and much higher speed) are the bane of a Bronco's aerodynamic happy place). Low speed has the stock fan not moving much air, and high speed building up high-pressure under the vehicle and impeding flow through the radiator. Bronco aero is not your friend usually.
Which is why I was curious what happens when your electric fan comes on at idle. With no load on the engine and good air flow through the radiator, that leans more towards low liquid flow through the radiator. Does it cool down while sitting when you rev the engine up?
And you're sure that, as a pusher, the electric fan is blowing the the correct direction?
Just checking...
Yes, under idle Rev it would cool down just a bit..
When I bought the rig, the motor hadn't been ran in 10 + years. So I'm expecting a few issues...
Bp
