Mullett
It all started out as a simple enough project. The Bushings on my just purchased 66 look as if they had never been replaced. One of the do-nuts was chracked in half and the C-Bushings were dried up and split all over. I did this job once befor on my 71 when I had it, and although I remeber it being a pain I did not run into the mega problems I have sitting in my driveway right now.
Where to start?
1. Both radius arm nuts wont budge. Neither would give up the Cotter Pins either. I worked on both to the point where the pins are sheered off even with the threads but wont tap out. I tried drilling one side out, and Im not sure what the hell happened the bit went all the way through, but the pin or at least most of it is still in there. I have tried heat and a monkey wrench but the nuts wont budge. I have a compressor and an impact driver but not a socket big enough, I am on my way to Home Depot to get one. But these things don't seem like they are going to give.
2. The spring retainer cups. One of my uppers cups is a little degraded, but seems O.K. Both cups however have flakey material between the upper and lower cups, almost like a wedge tapering from 0 in the center to about 1/4 on the edge. I do not remember from my 71 anything being in between the cups. Is this just 40 years of build up, or has part of the cup rusted and flaked away? All four seem pretty sound, but this flakey stuff concerns me? Any ideas.
3. One of the retainer cup bolts sheered off when I was trying to get it loose. It is the front one and I have the Radius arm front cap off. There is about 1/4 inch left sticking up from the cap. I have been pouring on chemicals from the top and bottom. Applying heat. and trying to turn it with vise grips. No luck. It is starting to round and I don't want to screw it up if there is a chance of getting it out. I am off to Home Depot to buy all types of bolt free catalyst I can find, but would love to hear some sugestions for how to get this out if any one has any ideas.
4. Lastly I have two frozen bolts on the other radius arm holding the cap on. I have busted two ratrchet extensions and my impact driver is showing no sign of busting them loose. Once again off to home Depot to buy catalyst and another extension. Any other suggestions.
I know if I can't get that bolt out of the cap I will have to buy a new one - since they are matched sets - this means a new radius arm. If things don't get better if any one has one for sale let me know.
Thanks in advance for the help.
Where to start?
