Radius Arm Problems -Need Help
Mullett
Manassas, VA
It all started out as a simple enough project. The Bushings on my just purchased 66 look as if they had never been replaced. One of the do-nuts was chracked in half and the C-Bushings were dried up and split all over. I did this job once befor on my 71 when I had it, and although I remeber it being a pain I did not run into the mega problems I have sitting in my driveway right now.
Where to start?
1. Both radius arm nuts wont budge. Neither would give up the Cotter Pins either. I worked on both to the point where the pins are sheered off even with the threads but wont tap out. I tried drilling one side out, and Im not sure what the hell happened the bit went all the way through, but the pin or at least most of it is still in there. I have tried heat and a monkey wrench but the nuts wont budge. I have a compressor and an impact driver but not a socket big enough, I am on my way to Home Depot to get one. But these things don't seem like they are going to give.
2. The spring retainer cups. One of my uppers cups is a little degraded, but seems O.K. Both cups however have flakey material between the upper and lower cups, almost like a wedge tapering from 0 in the center to about 1/4 on the edge. I do not remember from my 71 anything being in between the cups. Is this just 40 years of build up, or has part of the cup rusted and flaked away? All four seem pretty sound, but this flakey stuff concerns me? Any ideas.
3. One of the retainer cup bolts sheered off when I was trying to get it loose. It is the front one and I have the Radius arm front cap off. There is about 1/4 inch left sticking up from the cap. I have been pouring on chemicals from the top and bottom. Applying heat. and trying to turn it with vise grips. No luck. It is starting to round and I don't want to screw it up if there is a chance of getting it out. I am off to Home Depot to buy all types of bolt free catalyst I can find, but would love to hear some sugestions for how to get this out if any one has any ideas.
4. Lastly I have two frozen bolts on the other radius arm holding the cap on. I have busted two ratrchet extensions and my impact driver is showing no sign of busting them loose. Once again off to home Depot to buy catalyst and another extension. Any other suggestions.
I know if I can't get that bolt out of the cap I will have to buy a new one - since they are matched sets - this means a new radius arm. If things don't get better if any one has one for sale let me know.
Thanks in advance for the help.
broncnaz
Lots of penetrating oil let it sit over night longer if possible and keep spraying it down. Get the biggest wrenches you can find and possibly a cheater bar.
As for your spring retainers sounds like its rust but hard to say without seeing it. But usually rust will buildup between two peices of steel. as for the broken bolt I'd plan on drilling it out sounds like its rusted pretty solid. I'd plan on just drill and tapping the new hole.
Fullsize broncos and F150's use the same radius arm if you happen to run into problems.
Mullett
Mullett
Manassas, VA
Yes that is what I am using - and taking both of your advice I am trying to be patient. I will continue to soak them down as much as possible. I was able to file down the remainder of the bolt stub sticking out of my radius arm cap to fit a small open end wrench on it so at least i have something to turn besides vise grips. just hope it doesnt round off as I keep trying to apply pressue. Sounds like the going tip for now is spray spray spray, pray and torque. Any other ideas out there let me know.
Mark
Bronco Klutz
NW Indiana
Like the ancient greek scientist, Archimedes, said, "give me a lever long enough, ... and I will move the world."
ignore the cotter pins, get a wrench put it on the radius arm nut and get a long pipe to put over the wrench, it will loosen (or the wrench will bend), anyhoot, something will give. I sheared right through the remnants of my cotter pins.
Apply the same to the radius arm cap bolts.
The broken off bolt, it'll probably break off flush with the arm, at this point I would recommend getting a small Cobalt drill bit, say 3/16", and drill a hole in the bolt (a cobalt bit will drill into the steel of the broken bit fairly easily), and use a bolt extractor, it is reverse threaded, so as you tighten the extractor, you are loosening the bolt, and hopefully come right out.
BTW get a torch, use MAPP gas - it burns hotter, get everything RED hot, I mean get it damn smoking hot - it makes a difference, more so than chemicals.
Also, on my rusted crap (as my wife refers to it), nothing comes apart until I get good and pissed.
Have fun ;)
And another thing, I've taken apart - stripped down 3 broncos, I don't put much stock in penetrating fluid for loosening rusted bolts (PB blaster, WD40, etc..) the torch is your friend, Fire = Good.
Remember.... RED hot!
airman
If you wreck a radius arm I have a couple that you could have.
Mullett
Mullett
Manassas, VA
I may have to take you up on that Airman, but I have made some progress. Free at last Free at last both arms are off. This leaves me only two remaining problems the build up between the lower spring cups and the sheered off bolt on the R-Arm cap. I tried unsuccessfully to put a couple of pictures in to clarify what I am dealing with - On the cups I just am not sure if this is 40 years of build up stuck between the two or if part of the cups are rusted off and flaking away - It has been a while since I have seen some off and can't remember the exact shape. With the bolt - where I am at is working on the remainder of the broken stud. I have tried several times to file it down and turn it with a wrtench but it keeps rounding off. I also drilled though it and tried a bolt extractor, but it wont budge - I am having trouble turning the extractor - It has a square end and is too small for a socket. tried the drill low and slow but no luck there either. If all else fails I suppose I could try a machine shop, I have never tapped threads before and don't know if this is the part to learn on. Let me know if anyone has any more suggestions. If I could figure out how to put a pictue in it might help, but I am stuck there too.
broncnaz
Got to pay $12 to become a contributor so you can post pics. I'd just drill the broken bolt out and retap the hole thats the easiest to do dont bother trying to easy out it. If the easy out breaks they are way harder to drill out. Tapping is easy just have to make sure you use the correct size drill for the tap you are using most autoparts stores sell a tap and drill together makes it easy.
bludorbronc
If the bolt is sticking out, lay another nut on top and weld it on,the heat from welding will most times break the rust loose and it will turn out,doing so while hot. If you have broken bolts in the radius arms, weld a nut on to the end ,let it cool and take a torch and heat the arm where the bolt is stuck.You want a powerful heat source,like a oxy torch, so you can heat the arm quickly and not a slow heat where you heat the whole thing up together,so the parts will separate. And if all else fails hit it with a hammer ,always makes me feel better.
