rapid vacuum reading
nkhd1
I hooked up a vacuum gage to my stock 302 with 2bbl carb. I used the hose off of the PCV connection to hook it up (is this location OK?). Got her running and the gage fluctuates rapidly from 15 to 20 hg.
Engine has a hard time cranking -idles ok when warm. Runs good but bogs down after shifting gears (3 on tree) then picks up oK - doesnt do this all the time. If I adjust timing and mixture to get this to go away i hear a flutter when holding the gas steady.
I have replaced the entire ignition system, bought a rebuilt dizzy, rebuilt the carb etc.
I have sprayed around with carb cleaner and have not located a leak. I have not done a compression test yet - gotta get a tester.
Can anyone diagnose?
A compression test might not be a bad idea at this point. Some things that cause fluctuations like that (5 hg is not really that crazy an amount btw) might be a bad valve (needing a valve job), a vacuum leak (sounds like you've tested for that already), incorrect timing/dwell, and maybe taking the reading from the wrong place.
So, how many miles on the engine? Mine needed a valve job at 70k miles. Not common, but not impossible either.
Is your PCV tube that you're reading from, hooked to an individual manifold runner? Or is it hooked to the base of the carburetor, so that it takes it's vacuum reading from the center plenum area of the manifold?
Not sure that a single cylinder would cause fluctuation either frankly. I would actually think that even a single cylinder would read more smoothly than that.
What type of ignition are you running? If still points, double check them and maybe even replace them along with the condenser.
Your stumbling or hesitation during acceleration could be due to an over-lean mixture. This can be caused by a vacuum leak, an incorrect PCV valve, wrong jetting in the carb, and maybe other things as well.
What is your timing set at? Bogging can be not enough advance. What is your vacuum advance hooked to? Have you checked to see if the distributor is advancing properly?
And what do you mean by "has a hard time cranking" above? Does it turn slowly for a short time and then crank faster? If so, maybe your timing is too far advanced? Wouldn't necessarily coincide with the previous assumption that the timing is retarded, but it's still possible. Especially if the vacuum advance is hooked to full manifold vacuum. Better verify that too.
And finally, when did this start? Did it just start running funny all of a sudden? Come on slowly? Or, did it come right after you did something to the engine or peripheral components?
Miker
That second chance garage article was about the best I have seen to talk about this issue. Thanks for posting.
N
nkhd1
I don't know how many miles - bought the "69" in January - engine is a 68 torino. The PCV is hooked to a fitting in the manifold ('73). I have no other place to hook it up that I can find.
I am running points.
Timing is set at about 15. Reading is consistent. I was running about 10-12 but advanced it a little to help with the stumbling -and it did some.
"hard time cranking" it cranks fine just is cold natured and got to get it warmed up before it will idle. I have been having this problem from the get go just had other issues i was dealing with. along with money.
I wasnt looking for this project but thought it was a good deal and have really been enjoying it so far. This particular problem is about to get to me. I am almost to the point I could go have some fun in it and yet I cannot get this solved.
Thanks for the responses.
How much does a valve job typically cost? I had found the article posted but was hoping it could be something else. Haven't quite given up yet.
broncnaz
Valve jobs cost can be anywhere from a couple hundred on up. Overall by the time your done probably about $400+ If you dont know the total miles then you may have other things that need to be adressed as well. could need a total rebuild. 10-12 in of vacuum is pretty low for a stock engine so you definetly have a issue.
N
nkhd1
just did the compression check and most of em look pretty good 125-135.
I said most as #4 was 90-95.
Put an airline in #4 spark plug and put that cylinder on its compression stroke. Turn on the air and listen for where the air rushes out. If you hear it at the carb it an intake valve, hear it at the exhaust its an exhaust valve. Hear it at the valve cover oil fill its the rings. Coud be somthing simple as a mis adjusted valve. or as bad as a holed piston. Do you hear rockers clacking. if you do then pull the valve cover and make sure you dont have a broken valve spring. a broken valve spring can ruin your day in a hurry.
N
nkhd1
thanks
I am planning on doing just that. Got teh pieces here at work and will try it - 30- 50 pounds should do it huh?
Maybe it's just gummed up a bit inside, and needs to be run for awhile. If that's the case, a few thousand miles with some solvent-based oil additives in the crankcase (yeah, the "snake oil" stuff) and a couple of oil changes will free some sticky, gummed up rings and clean up the rest of the crankcase for some good running in the future.
It worked wonders for mine, when I first bought it.
Where in the manifold? Got a pic you can show us?
Is there no 3/8" diameter port at the base of the carburetor?
Stock 2bbl, or aftermarket 4bbl carb?
Is it generally running alright? Smooth idle and all that?
I see below that you're running a bit cold-blooded. Could be lean fuel mixture, could be a malfunctioning choke, could be a weak ignition.
Or it could be all of the above. And then some...
Common enough. Should have run fine at 12, but you'll need to eventually verify that your timing point and marks are lined up correctly, your mechanical and vacuum advances are working properly, and that your points and condenser are optimal.
And then you'll have to find out why it's acting lean in some things (bogging, cold blooded, etc). Maybe triple-check for vacuum leaks, the wrong PCV valve, wrong carb base gaskets, or maybe even the wrong carb.
Could be carb, could be timing, could be weak ignition spark. If was actually having a hard time cranking, that can be due to more ignition advance than it can handle, too much compression (seemingly not an issue here), or a weak starter. Since it sounds now though, like the cranking part is fine, I'm assuming that it just doesn't want to fire easily when it's cold?
If so, have you checked that the choke is closing fully? If it is, then maybe we're back to a too-lean mixture.
Is the carb the one that came on the engine, or one you had? If the one that came with the engine, do you know if the PO had it running at all? Or were they perhaps selling it because they couldn't get it to run right?
N
nkhd1
new info
Did a wet test on #4 and have 185psi and holding for over an hour.
A friend suggested a stuck ring causing the low compression.
It may not be my only problem but...
It is a 302 with a 2bbl carb. The bronco had been sitting for 3-4years in a garage.The 2bbl is not original but a reman that i had to put a kit in. The PO said the engine had been "gone through". I have pulled the valve covers and it is very clean - no sludge or any deposits.
broncnaz
Or some marvel mystery oil in both the crank case and the fuel tank I'd also pour a little in that #4 cylinder as well let it sit for a day or more.
Part of your hard starting and cold natured issue may be the timing usually I find that more than 12 degrees and it gets harder to start. Some electronic ignitions actually retard timing for easier starting.
Carb shoud be ok other than fine adjustments unless there was a lot of varnish/gum in the carb when you rebuilt it then maybe it still has some in the passages and needs another good cleaning. Seafoam in the gas tank might help in that area if you dont want to pull the carb apart.
