I hooked up a vacuum gage to my stock 302 with 2bbl carb. I used the hose off of the PCV connection to hook it up (is this location OK?). Got her running and the gage fluctuates rapidly from 15 to 20 hg.
Engine has a hard time cranking -idles ok when warm. Runs good but bogs down after shifting gears (3 on tree) then picks up oK - doesnt do this all the time. If I adjust timing and mixture to get this to go away i hear a flutter when holding the gas steady.
I have replaced the entire ignition system, bought a rebuilt dizzy, rebuilt the carb etc.
I have sprayed around with carb cleaner and have not located a leak. I have not done a compression test yet - gotta get a tester.
Can anyone diagnose?
