jeremywatco
Evening,
Finally getting around to swapping the 3.50 front and back to 4.11 with the 33's I put on.
Trying to figure out what I'll need to bring to the shop. Assuming in the rear I can pull the axles and just unbolt the third member (leaving yoke attached) and pull it off and take to the shop.
The front on the other hand... I thought the front doesnt fit out of the case unless you have a special spreader or something.. so trying to figure out what I need to do to get it down to the shop? Leave the tubes attached and take the entire front off? I have new C-bushing.. maybe a good time to do that as well? I keep putting off the C-bushings as I've never found a safe way to lift the front frame off the ground.. I did a spring swap a long time ago and was scared for my life with a rigged up wood block.
Any thoughts?
Thanks, Jeremy
Any thoughts?
Thanks, Jeremy
