Rear axle seal replacement
Bartonatl
Atlanta
I have a leaking rear axle seal, driver side. I pulled the old one out, and will probably go ahead an replace the pasenger side too. Should I go ahead and replace the bearings too. They are pressed onto the axle. Can I just pack some grease on them. How would I know if they need replacing? I have some pics I will post.
johnnybgood74
boise, idaho
i would replace the bearings too. just a piece of mind really. if they look pitted, scarred or have excessive slop then i would replace.
Viperwolf1
electron whisperer
The bearings are sealed. You can't re-pack them. If you try you could damage the seal then they'll be done. If they turn smoothly and don't have a lot of slop they're probably ok.
broncnaz
Do you know how many miles are on the bearings? If more than 50K or unknown I would swap them out. Its kinda of preventive maintenance do it now before it actually needs it or do it later because you have to and hope no other damage is done.. Many times(but not always) when the seal starts to leak thats a sign that the bearings are about to go bad.
Bartonatl
Bartonatl
Atlanta
OK. I will replace them since most of the work is tearing the axle out. Where would I go to have new ones pressed onto the axle?
Bronco Maniac
Others can provide a lot more detail and technical info. Heat the bearing and it will slide onto the axle. There are two sizes of axles and therefore two sizes of bearings. You can measure something like the brake drum to determine which you have, I don't remember.
broncnaz
Some of the better parts stores can do it. Might have to take it to a machine shop that has a press. While you could heat the bearing its not a very good idea since its a sealed bearing if you heat it to much and destroy the seals and the grease comes out then your screwed.
lil mule
ALBUQUERQUE
stick them in a 200-220 deg. oven for 2 hours. while they are heating make sure there are no nicks or burrs on the shaft. use some leather gloves or something like that . wrap them in foil before you put them in the oven so they will retain heat on your way to the bronc. go from oven to shaft asap, take out of foil and silde on shaft.
Bartonatl
Bartonatl
Atlanta
Awesome, thanks for that info. guys. I will post again as I get this done and put up some pics.
DevilDog
Virginia
I hope he nothing bad happened, it's been days since he put the bearings in the oven.
Actually, I have to do the same thing to mine, so I wanted this post to be back at the top.
Bartonatl
Bartonatl
Atlanta
Devildog, this post has already been updated. See the updated post and the newest update......"rear axle bearings...What now?...from yesterday. In a nutshell: go ahead and put in new axle seals, new bearings, and new retainer plates. It's just easier that way. Look at the pics I posted in the last update. And personally, for me, its easier to find a machine shop and pay someone to cut the old bearings off and press the new bearings on. $15 each. That's just me. Found the bearings at O'reilly's for $35 each , got them same day. NAPA has them for $45. I heard don't use the ones made in China..??.. oh yea....do use axle grease RTV seal around the axle seal. Got it at NAPA off the shelf. Buy an extra axle seal because you will screw up one of them.
