Rear brake shoe placement
AzBroncoGuy
I have a question on rear brake shoes. The standard placement is the larger shoe to the rear. The shoes that I got have the same length of lining on both shoes. The difference is that one shoe has the lining that ends closer to the top of the shoe than the other. The other shoe has it's lining further back from the top but much closer to the bottom. Can anybody tell me which one should go in the front?
Never seen that before. Just to be clear that of the 4 shoes, all have the same length of pad material. Two have the pad material centered on the shoe and two have the pad material offset toward the top.
Just thinking through how brake shoes work and self energizing pad theory... The offset ones toward the top would be leading shoes and the centered would be trailing shoes. Unless there is a manufacturer discrepancy to that.
m_m70
Prescott AZ
Where did you get these shoes from?? Haven't seen this before for Broncos.
Pics would be helpful. $12.00 a year well spent and helps keep the site going!
AzBroncoGuy
AzBroncoGuy
Yup I've never seen that until now. These shoes were put on so long ago that I can't remember when or who I got them from. I didn't like the wear that I saw so I've got a new set coming that has a long and short shoe. Problem solved!
Thanks for your input.
AzBroncoGuy
AzBroncoGuy
I've not seen this either. Shoes were put on so long ago that I can't remember who I got them from or where. Anyway I've got a new set coming with long and short shoes as I didn't like the uneven wear that I saw on the shoes.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Bought rear brake shoes from Wild Horses December 2022 that were just like these.
3120 3121Brake Shoes, Front or Rear, 66-77 Bronco - 66 - 75 11 x 1 3/4 Rear Shoes
Double66
This is how my brakes looked after I installed them on my 68. Never noticed until now that the front shoe is slightly shorter than the rear.
Steve83
...I've got a new set coming that has a long and short shoe. Problem solved!
Do you know what brand the wrong shoes were, so others can avoid them? What brand are the new ones? This page shows a full set of eB drums, including the ebrake linkage:
(click this text)
This & the NEXT dozen show how to assemble rear drums (almost without tools):
(click this text)
AzBroncoGuy
AzBroncoGuy
Well after getting another pair of brand new shoes from O'Rielly, they were the same style. I did several hours of research and talking with some really good professional experienced mechanics and found this out. The shoe with the thicker lining always goes to the rear. Apparently this type of lining placement is more common than we know.
BradGP
