- Oct 14, 2004
- 5,001
I have several transfer cases and need to rebuild one to replace the one I'm running now. I want to do it using the best parts from each, basically a hybrid T & J.
I ordered the new shift rails from JB Fab that they claim are designed to help with popping out of gear so will use those with all new bearings and seals.
Use a J case
Use T gears
Use J front output shaft
what else? and am I correct on the above?
I have WH HD output on the case I'm running now that will be used on the rebuilt case.
Also, how do you identify T vs J gears? I have a box full of gears that I got a few years ago that I'm not sure what they are.
Use a J case
Use T gears
