Relay Issues?
Tony Mele
Hi gang,
Was cranking on my Bronco to start - but held the ignition engaged longer than usual because I haven't quite gotten used to the new tuning on the carb, and was having trouble getting it to fire up.
Suddenly she stopped cranking.
I have power. Battery is strong.
Just one small click when I engage the ignition. Not repeated clicking that would indicate a weak battery.
If I cross the terminals on the relay connected to the battery, she fires right up!
Help me diagnose this please? Did I somehow burn out my relay? Or should I be looking elsewhere?
T
RedLeg0811
Maltby, WA
Sounds like your Starter solenoid is bad. I think the are like $20. Been awhile since I bought one, so I can't really remember.
Tony Mele
Tony Mele
That's where I'll start. Thank you. It's been so long I forgot they were called solenoids and not relays
Tony Mele
Tony Mele
New solenoid is in. Still won't start.
If I jump the solenoid by connecting the two sides, it starts right up.
If I turn the ignition key, I have power to all accessories/lights etc.
If I engage the ignition key, nothing happens.
Any ideas where to look next?
T
hankjr
Bad connection between ignition and solenoid? Check for loose / broken wires?
Hank
Tony Mele
Tony Mele
I'm looking Hank. No bad wires (yet).
Is it possible my ignition switch has failed, even though it powers all the other accessories and lights?
Steve83
You have to PROVIDE a lot more information. %) We need to know every detail about the truck, particularly: is the wiring harness original, repaired, aftermarket, home-made...? What engine? What trans? What starter? What damage/mods/repairs/maintenance? There are many things you might not realize that can cause or influence this symptom, so don't leave anything out. Don't tell us anything is "stock" or "factory" because there were MANY factory options, and just because something has been on the truck since before you got it doesn't mean the factory put it on.
Put all that information in your SIGNATURE so it appears automatically with every post (even your previous posts) - don't post it where it will get buried in this thread. My signature is NOT an example - look at DirtDonk's.
JWMcCrary
Is this an automatic? Are you sure it's in park if so? Haven't mentioned until now because you said in your first post you would get a click, but you could have had a bad solenoid and also not be engaging the park/neutral safety if it's an auto.
Tony Mele
Tony Mele
I'm not with the vehicle now but I have wondered if somehow I slipped it out of park. But I will say that my hands were nowhere near the shifter when this problem occurred.
With all due respect to the other post I don't think that all of that information is relevant. I could be wrong. But the mods I have and my maintenance schedule don't seem to be the problem. Listing my factory options and engine displacement? The engine displacement should have absolutely no bearing on this problem. My ignition was working one minute - and has been since I bought the truck - and the next it wasn't. The only parts of this that I can see that I should have added are relevant to the ignition. I have no clue if the wiring harness is original or not. It is an automatic transmission. And the type of starter I have? As soon as I get electricity to the starter it operates perfectly. I don't know what type of starter it is, or why that matters.
I'm not a problem mechanic, and I'm definitely not attempting to start an argument. But I cannot understand why all of that information is critical.
Tuloyuser
I recently had the same problem and mine turned out be the neutral safety switch. I isolated the NSS by jumping it test..
It is also possible that you have a bad "new" starter solenoid, I had to go thru 2 of them.
Good luck,
John
Tuloyuser
Neutral Safety switch would be found where on the trans?
BTW... Goes without saying that do this only for testing purposes etc...
and make sure the transmission is in park etc.
When I had the problem, I just basically checked everything.
-starter
-starter solenoid
-nss
The only one I didn't get to test is the ignition switch.
Here is a pic of where the NSS is attached to the transmission
And this is where I jumped the switch. (make sure truck is in park if you are going to do this).
John
Tony Mele
Tony Mele
Thank you so much for your help. I must admit to my own stupidity now. It seems that the shifter on the column is extremely loose. The truck was not in park. It had been. I must have just touched the shift knob. I got in the truck and pulled it down to first, then back to park. Started right up!
jw0747
San Antonio, TX
We could have never diagnosed the problem because you never provided us with all that important and relevant info. You also needed to supply us with the interior and exterior colors + amount of air in the tires. Wink, wink...
bronconut73
Haha....
Made my night....lol...haha...
Glad you got it straightened out.
Nope, you were right the first time Tony. While it might have come to be known as a "solenoid" it is in fact a relay, and that's what Ford calls it.
There are plenty of references to it being a solenoid nowadays, because we've spent forty or more years calling it that so that's what many ask for when buying a new one, and what many parts people know it as too. But in the old books and by definition, it's still a relay.
Calling it either one should get you there.
Well, all of it might not be pertinent this time. But what about the next? That info might come in handy later is what Steve is telling you and you won't be asked again to go down the list of things that have been changed or not. And that some of it might have even come in handy this time if the answer had not come to light so quickly.
If this no-start issue is the only trouble your Bronco ever gives you, then we may not need to know what other stuff after all (and lucky you!) but that's not very likely either.
So it's still good to have all that info in your sig.
You mean the "starter" not the "ignition" so even the wording can come into play.
And things like the neutral safety switch that's only present on automatics '73 and later, or the failure-prone jumper wire connection on trucks of '73 and later vintage equipped with the manual transmission. And only with a stock original wiring harness.
See where this is basically going?
Well, since you're not that familiar with these things, let us tell you, it can be critical to know some of the stuff being discussed to help with a problem.
If you don't know it, we don't know it either and have to ask questions. Hence the practice of placing all the info you do know in your signature line so we don't have to ask again and again as different problems crop up (as they often do) especially on newly purchased Broncos. Even here though, we didn't know you didn't know until you told us. I think most EB owners do have a fairly good idea of what's on their rigs, and driving old trucks like this tends to make you more familiar with the details than perhaps you like to be.
So as you get to know the details, adding them helps us too.
Again, you merely got lucky this time when it turned out to be the loose shifter. At any other time diagnosing a "starter not spinning" issue much of that info is absolutely critical to us helping you diagnose and fix the problem. Period.
Knowing if it's a stock or aftermarket wiring harness and it's condition, stock or aftermarket ignition switch, stock original or later type or aftermarket starter, stock transmission, stock etcetera, really can help.
We go through it all the time as you may have already seen if you've been reading similar posts. Lots of possibilities exist.
Not knowing every intimate detail of a Bronco is not uncommon even if you've owned it for a long time. But as the details become known to you, it's nice to make others aware of them when you ask questions.
Steve wasn't trying to start a fight either. Just pointing out something that you obviously didn't know that could help find your trouble.
And I'm not either! Just throwing all that out there to help you understand why we ask stuff like that.
Tony Mele
Tony Mele
I appreciate all of that, and don't disagree. I just didn't see the relevance for some of the issues (engine displacement, make of starter) while I was elbow deep in this and trying to dictate into my phone.
I've never seen a gear shifter that is so sensitive. Literally if I just tap it, the vehicle won't start. It's gotta be really up there in park!
So...the more important question now is this: how do I edit my profile and signature to add the relevant info, since I've already got a new list of issues to ask about.
And how do I change my name signature. I'm not thrilled that it actually is my first and last name on there.
And finally, now that I've got the truck back I've got to get the money together to get those headlights we discussed a few weeks back. I drove last night, and I could throw a rock - a large rock - farther than my headlight beams project.
T
Tony Mele
Tony Mele
Found the signature edit on the CP. Now trying to determine how to change my name at the Avatar section.
JWMcCrary
That is very common with stock steering column automatics in the bronco. I rebuilt my column 12 years ago and within a few years I was having that issue again. I'm so used to it that I push the shifter before starting it almost every time without thinking. I noticed a few weeks ago at the muffler shop the guy working on the exhaust asked another worker, man in his 40s, to start the bronco so he could check for leaks and he pushed the shifter before starting it.
For clarification, the switch is on the transmission where the shift arm connects. That's makes several places where there can be slack between the Trans and the shift arm. Doing a little investigating you find that you can improve your particular situation without getting into the steering column.
JWMcCrary
You can also use the garage feature without trying to figure out what all is important enough to squeeze into the signature line.
