Relay Issues?
Tony Mele
Tony Mele
Thank you. I learned my lesson.
That is very common with stock steering column automatics in the bronco. I rebuilt my column 12 years ago and within a few years I was having that issue again. I'm so used to it that I push the shifter before starting it almost every time without thinking. I noticed a few weeks ago at the muffler shop the guy working on the exhaust asked another worker, man in his 40s, to start the bronco so he could check for leaks and he pushed the shifter before starting it.
For clarification, the switch is on the transmission where the shift arm connects. That's makes several places where there can be slack between the Trans and the shift arm. Doing a little investigating you find that you can improve your particular situation without getting into the steering column.
Hah! Yeah, one of the old "assume the positions" habits while starting an older car was to reach around the column with the left hand, grasp the shifter and hold upward while turning the key with the other hand. Wasn't just Fords of course, but we certainly had our share.
This is one of the reasons that the NSS is actually adjustable. I'm sure it's mainly to cover manufacturing variations, but will also work to compensate for age up to a point.
And switches go bad too don't forget.
You might check it at night too, to see if the backup lamps illuminate when you expect them to in reverse. Or if you have to jiggle the shifter to get that to work too.
As always, have fun!;)
Tony Mele
Tony Mele
Thanks Paul. And I took Steve's advice and modified my signature.
Hey! Look at all that pertinen... uh, I mean good info!;) Thanks.
Steve should be happy now. Hmm, or did you leave anything out I wonder. He'll pick up on that in a jiffy. And we don't want to get him riled up and on another mission!
Just kidding of course. It's good info!
On your other question about the username, only Jon the ADMIN can change that, but it would be unusual to do that. Not sure if you can do it cleanly, or end up starting over.
If starting over, you can do that yourself by simply not using this account anymore and starting a new one with new username and password.
Not sure if that's feasible either though, if you want to use the same personal e-mail address to receive notifications. Might be a conflict.
Anyway, PM ADMIN and see if he has any suggestions.
Steve83
What exactly does "auto/PB" mean? Is there something automatic about the power brakes, or do you mean automatic transmission? Which model is the transmission? Post as much of its history as you know (miles, rebuilds, parts, mods, problems, repairs...). That's one of those things that can affect cranking, in several ways. If you're bored or curious, check out what this guy did to himself:
http://www.fordf150.net/forums/viewtopic.php?f=81&t=122776
Tony Mele
Tony Mele
I'll fix that Steve. I meant Auto trans and power discs front brakes. But the signature line limits how much can be written.
kip60
Well, at least you got a new starter solenoid out of the deal!
JWMcCrary
There is no way you can put every single thing about your rig for any problem that may come about. Don't be intimidated by someone who doesn't have anything in his signature line. Fortunately, the vast majority on here are not idiots and can figure out abbreviations for auto trans, power brakes, power steering etc.
Steve83
Then leave out the stuff that we already know, like "19" in the year, and "Bronco". If you shorten it to "73Sport 351W Holley650 long tubes duals DynoMax, MSD, org.wiring, 2.5" 33s a/t power fr.disc PS", you'll have a little more room for other details that we might need to know.
Do you mean YOURSELF? %)
I don't have a description of my eB in my signature for 2 very good reasons:
1) it's a naked frame;
2) I'm not asking technical questions about my vehicles.
I'm TRYING to answer other people's questions, but it's difficult when THEY don't provide enough info. And posting it doesn't help because, as a thread progresses, no one is going back through every old post to find out if the OP ever posted his truck's details. So as much as possible needs to be in his signature under every post just in case we need to review it at any point. My signature won't help him (or me or you), but there's a lot more info in my signature link about my truck than you have in yours.
Fortunately, the vast majority on here are not idiots...
Do you think you're in that majority?
...abbreviations for auto trans...
Do you see the abbreviation for auto trans in his signature? Because I didn't, even though I know what it is.
1973 Bronco Sport 351W, Holley 650, long tube headers, dual dynomax exh, MSD elec. ign., 2.5" lift/33"s, original harness, auto/PB front disc/ PS
rmfreeze
Benton, Arkansas
... one of the old "assume the positions" habits while starting an older car was to reach around the column with the left hand, grasp the shifter and hold upward while turning the key with the other hand.
That's it. Leave it and just think of it as a theft deterrent. ;D
JWMcCrary
Then leave out the stuff that we already know, like "19" in the year, and "Bronco". If you shorten it to "73Sport 351W Holley650 long tubes duals DynoMax, MSD, org.wiring, 2.5" 33s a/t power fr.disc PS", you'll have a little more room for other details that we might need to know.Do you mean YOURSELF? %)
I'm TRYING to answer other people's questions, but it's difficult when THEY don't provide enough info. And posting it doesn't help because, as a thread progresses, no one is going back through every old post to find out if the OP ever posted his truck's details. So as much as possible needs to be in his signature under every post just in case we need to review it at any point. My signature won't help him (or me or you), but there's a lot more info in my signature link about my truck than you have in yours.Do you think you're in that majority?Do you see the abbreviation for auto trans in his signature? Because I didn't, even though I know what it is.
Maybe you and Frank need to become detectives because you were correct to assume my post was directed at you. You do not have to read between the lines, I will say straight up that I have a problem with you. The only reason you are here is because you were banned from the big bronco site, of which you claim to be a guru. But, today is your lucky day because I was reminded by others that you can be put on ignore, hmmm, seems I'm not alone. So educate away Mr. guru, you don't have to worry about me seeing or replying to anything further that you post.
