You are chasing the wrong problem. The Bronco ampmeter is inductive. Doesn't suffer the burn out issues that full pass through amp meters have.
The real problem with upgrading the alternator is the wiring isn't big enough to handle the added current. Bypassing the amp meter does not fix the undersized wiring issue.
While I don't want to do a major hijack on the OPs thread, can you take a look at this and make sure I'm on track:
Got a Mega Fuse harness from a 98 F150, also has a 20 amp fused Yellow/White wire and the Green/Red wire to use.
- Unhook Voltage Regulator, take Yellow wire from connector, attach to Yellow on Mega Fuse harness. Take Green/Red wire from connector, attach to Green/Red on Mega Fuse harness.
- Remove Orange wire completely. Cap Black/Red and Black/Yellow.
- Put Mega Fuse harness on B+ starter relay terminal to B terminal on the Alternator.
- Leave the Ammeter alone until I convert to Voltmeter.
I just wasn't sure on the Ammeter because I couldn't find a definitive answer.
Thanks again, and sorry again for the hijack...
