Replacement EGR valve direction
BDK2013
Duvall, WA
Please help,
After rebuilding my carb and cleaning out the egr plate I forgot to not which way the egr valve went on.
Does the plunger slider of the valve (inlet) mount to the passenger side hole with the return on the driver, or flip it over?
I guess also the outside vacuum nipple is above the return so does it point pass or drive
Yes bonehead move
B
BDK2013
Duvall, WA
Yes the plunger is the heated exhaust intake, just not sure which opening (left or right) is the exhaust port side.
I believe the exhaust inlet to the egr is on the passenger side of the back carb plate and the right side of the carb spacer dumps below the Venturi?
B
BDK2013
Duvall, WA
I know pics, pics, pics. But in lew of that, when you look at your carb and the egr spacer pointing out the back, the left side (passenger) looks to mount the plunger and putting the return side right (drivers) .
Guess I will try both ways and see which runs better
Ovalis
Los Angeles
Just look at the spacer itself. the outlet of the egr (non plunger side) will line up with the hole in the spacer that goes to the throttle bore. The plunger side will be lined up with the hole in the spacer that will most likely caked up with carbon that you cleaned out. If I'm not mistaken, I think the bore diameters are different anyway so that should indicate it as well. Also the diaphragm of the EGR is probably angled so when you mount it, it should be facing up.
