replacing heater core
White Knight
Is it necessary when replacing heater core to get an aluminum one if you are running an aluminum radiator?
RustBeltRefugee
Santa Clarita
Should be fine. Kepping your cooling system maintained with quality antifreeze and distilled water should limit corrosion no matter what metals are used in the plumbing.
White Knight
White Knight
thank you for all the responses~ I am doing full re-furb of the heating system and really appreciate the guidance.
White Knight
White Knight
Replacing heater core
While replacing core (went with the oem version) decided to clean everything to the bare metal, primer and paint all the parts. Ready to install new seal kit:
RIbronco
Costa Mesa, CA
^ Those came out nice.
When it comes time to install the foam parts 3M Super 77 contact adhesive works really well to adhere the door flap foam in place. After several years, its still holding mine in place.
White Knight
White Knight
Replacing Heater Core~ full rebuild
Got the seal kit installed, all new stainless screws (painted the heads- black). For the holes where I had to drill out the rivets to get box apart, I used screws and nylon insert lock nuts on the back side~ worked great.
Ready to install:
Fireball05
Looks great - nicest looking rebuilt heater box I've seen! Make sure you give all your heater controls a nice coating of silicone spray for silky smooth operation prior to reinstalling.
Speaking of which, have you test fit it yet? I'm thinking those heater core ends look a little long and you're going to have a hard time fitting the hoses against the PS fender. Maybe it's just the angle the picture is taken at, though I read a few different reports of folks having problems with the newer cores.
White Knight
White Knight
replacing heater core and refurbish all components
Thanks for the comments~ it was a enjoyable project but now I have to install it. I do believe the core tubes are going to be too long and hit the fender well not allowing me to fasten the hoses~ is there an issue with just cutting them down or should I try to bend them?
White Knight
White Knight
had my 16 yr old help me install today.Had him hold the heater box to where the core pipes were barely sticking out of the firewall, sprayed them down with silicone and they went right on.
The hoses were definetely snug against wheel well but installed beautifully, no leaks and for southern California~ heat blew me out on low.
thanks everyone for their advice and feedback.
on to replacing my 3.50's to 4.11's ~ just finished taken the 3rd member down to the metal, 2 coats of primer and 4 coats of engine enamel
ChrisC74
Install looks and sounds like it went great. Can you tell me which vender / store you purchased the OEM heater core from??
Thanks,
Chris
