Revell build thread,post your status too
JWMcCrary
I used Testors Clear Parts Cement. It goes on white but dries clear. It was a little thicker than the regular model glue.
That's what I have. I don't think I shook it up enough. I just pulled the windshield back apart and cleaned the glass....do over number ?? who's counting.
ared77
phred, Man that one on the trailer looks so much like my previous real '73 Bronco! I thought I was seeing one of my pictures for a split second! ;D
phred
Earth
Wow. No kidding. If yours had explorer trim on it our real broncos could be twins
phred
Earth
Ok it not a bronco but it is ford powered. I finished it up last night. Wanted it to look fresh off the track after 24 hrs of racing.
The body has a slight bow in it. The nose points up just a little. I glued it down and left a bottle of glue sitting on the hood to flatten out the bow but it's still there. Not as bad but I notice it.
No Hay
Wow, she's a Beauty! Nice work on the detail.
JWMcCrary
Calling this one done !
There are a few boo boos, such as the windshield wasn't seated properly and I didn't catch it until the glue was set and I had a wiper on. Going forward I will be more careful with painting pieces that need glue, that was a tough work around on this one. And those stripes down the side, holy hell!
sprdv1
REBEL
Nice man.. looks good
CopperRanger
Nice job, I like the color. I think if I do another I would do a few things different also.
San Antonio
Skiddy, other than cut the fenders how did you "lift" yours, & what tires are those? I found the fender flares on eBay and while I've found lifted Ford axles, they are all full leaf packs...thanks for sharing!
Skiddy
Skiddy
on the axles/tires, I had an old plastic bronco toy. It had solid axles so I just cut the shaft off and put them the housings. if I was going full width I would have ground down the shafts to the original bronco size shafts, and put them in the housings, it then would roll just fine.
I have a little bit of rebuilding to do since the wreck%), I will post some pics after while
CopperRanger
Haven't had a lot of time lately to finish mine. I did put a few decals on and like slowleak said, glued a few parts back on that broke off from handling. :(
Skiddy
Skiddy
got the suspension redone. power brakes installed, worked on the roll cage%)
Golfball
I have that same Cobra kit still in the box that I bought back in 1990 in Guam, during my first assignment in the Air Force. Now if I could only remember where I stashed it.%)
Skiddy
Skiddy
You're not the only one looking at booger welds.....;D;D;D
lol know what you mean;D took a grinder to it and rebuilt the whole thing, got a little tweaking to do. it does fit under the hard top though
