an electric water pump? are they good? dependable? any thoughts?
are there any that can supply heater hose outlets?
Great for drag racing, burst of heat, 30 minutes of leaving the engine off and let the pump and fan cool off the block. Repeat.
Think of this, if it was any good some manufacturer would have done it by now. Closest they have done is an intercooler circulating pump. Only a fraction of the flow needed to keep an engine cool.
Dependable? The mechanical water pump has very little in it. Bearing and a seal really. Electric has those parts
and all the eletrical stuff to go with it. And unlike other eletrical things that have had millions of dollars invested in them by a manufacturer to make them reliable, the electric pumps are all aftermarket.
There are a few out there that might work. I have seen them at SEMA for years. Good ones are very expensive. And you can't get parts on a Friday evening.
All this can be fixed with an off the shelf reverse rotation waterpump and a crossover pipe. Any backwater town can get an off the shelf waterpump.
The crossover pipe has zero moving/wear parts so no worry there.
