Right Blinker goes soild when I apply Breaks
Fathom
Los Angeles
Any idea why my 'Right' blinker works fine until I hit my brakes, then it goes solid.
My left works normally.
All of my bulbs are good.
I did swap out my column recently, but I thought it was working correctly when I was done.
THANKS
I hate ripping out the seat so I can fit under the dash.....
Brian
RajinCajun
HawleyTX, La orig.
Your blinker fluid is about a quart low :)
Bet you have a short or it is wired wrong.. Does it have a trailer plug? If so check that area of the wiring too.. I have seen lots that were thrown together in a hurry and not done very well at all...
bigben128
Sounds like a bad ground to me...Same thig happened on my Old Mustang. Turned out the housing was missing a screw. I replaced it and it worked fine. Good luck!
Fathom
Fathom
Los Angeles
Now that is a good idea to check. THANKS!
I think my dipstick broke off in my bulb fluid reservoir, I can't check the level:cry:
Hmmmm, I'll check the plug.....thxs
Brian
hose101
just pump the brakes when you want to turn right. problem solved... I think;D ;D ;D
Fathom
Fathom
Los Angeles
Found IT!
I had recently installed a new column and did not realize I had a problem.
The PO must of had an electrical problem and decided to add in his own wires.
He tapped into the right blinker that feeds the column instead of after the switch. Plus he added a second lamp in the tail light that was fed off the wire he tapped.
66 broncos only have 1 light bulb in each tailight, so that was easy to spot.
So once I put the wiring back to stock (Thanks to seabiscut's colored diagram), it WORKS!
THANKS everyone......
Brian
