Right turn blinker issues
Bronk74
North Las Vegas
Left turn signal works fine but right turn signal, the indicator on the gauge cluster stays on solid, if i have the head lights on and use the right hand turn signal the rear light completely goes out. Even with head lights off same thing. Any help is appreciated. I haven’t done a deep dive yet
phred
Earth
Do both the front and rear blinkers not work? Do the hazards work??
The first thing I’d look for is a bad ground. Check them all, clean the ring terminal well, sand the contact spot to bare steel and make sure the housings are good. I’ve had housings that were bad.
SHX669
Another thing easy to check is if the correct bulbs are installed - dual filament vs single and dual contact "post " vs single - I've seen em swapped .
Only on a related note for future projects you might encounter - lol - I've also seen the front turn signal / caution lights wired backward or at least on an aftermarket wiring harness. I burned out a front bulb in a relatively short period of time and when I went to replace it the bulb had obviously gotten too hot. Turns out if the wires in the new harness are reversed the one smaller filament gets too much voltage for too long when you have your lights on .
