Rocky Mtn Customs and Classics comments
RnrdTheFox
Superior, CO
Hello,
I'm in need of some body and paint work. A fellow bronco owner on here referred be to these guys. I'm curious what others have experienced with them. Their webpage shows several bronco projects. Any feedback good or otherwise is appreciated. If you don't want to post something, please PM me.
The things I need done:
- Lower left front fender rust repair. Bottom rear 6" section
- Lower right rear fender rust repair. Bottom front 6" section
- R&R driver rocker panel
- R&R driver inner apron and kick panel
- Repair on fiberglass hood where it popped up at 55 mph when a neighborhood kid thought it would be funny to take my hood pins
- Inner cowl repair. I don't know the extent of this yet.
- Finally, paint.
thanks,
Renard
needabronco
Prescott/Farmington
I'm going to jump and say you'll be paying those guy's anywhere from $45-95 an hour for labor, so it'll be cheaper to replace the front fenders, and quite possibly the hood. As for the rest that should be fairly straight forward to repair. I'm also going to say a 'cheap' paint job is going to start at $5,000 but will likely be higher on up to a show quality job which will ball park between $15-25,000. Just depends on what you want? Good body work isn't cheap and cheap body work will need to be redone in a year or two...
JoePro
I'd cruise it down to Bronco Hut in Castle Rock and get a quote.
JGZ
X2 on Bronco Hut.That's pretty much their specialty.And it's local.
