Roller motor question (LOUD Rockers)
treihesse
I have a built 302 with Comp roller tip rockers, Edelbrock Torquer cam, TBI EFI and I have a 2000 miles on it. I have a little rocker noise. The motor was broken in with 1200 miles and then it sat for 3-4 years. The rocker noise is on the driver side. Should I run a cleaner thru it? Do they need adjusting? Please I need motor GURU. Or could this be valves??
Viperwolf1
electron whisperer
If you can pull the valve cover easily, check the adjustment (if its adjustable).
hdfx81
I have the same problem with my fresh 302, steel rockers with roller tips no matter how I adjust them they make a slight noise, even when they are too tight and the engine runs rough you can still hear a slight tick like solids but not as loud. I was wondering if that is a characteristic of these rockers. I have screw in studs so they are adjustable
JWMcCrary
I believe it is. Mine are noisy also but runs well, I adjusted them many times and they are still noisy. I let a couple drag race friends look at mine and both said it was fine.
RajinCajun
HawleyTX, La orig.
The 351 in my Stang has Crane roller tip rockers and Windsor Jr heads, it did exactly the same thing. Adjusted them and got some of it out, but not all. Put a quart of Rislon(yellow bottle) with an oil change and haven't heard them since... Just as a option, you may try it.. Now I put Rislon in all my rigs.
Buldozer
Bronco Virtuoso
God's Country
Mine are a little loud also, but you have to know what to listen for to hear them. Before I readjusted them (you should be able to spin the push rod when the rocker is up all the way but not have any slack), they were real loud...now just slight noise. Mine have to be shimmed since I have the pedestal type.
misterkeebler
from my experience they all sound a little louder than their hydraulic counterpart, they should sound kindof like a sewing machine and thats pretty normal, but they should ALL sound that way. if you have a particular one that is loud then you may have a problem
treihesse
treihesse
It runs great!!! I think it may have some dirt/gum in there. Any ideals on a good cleaner??
misterkeebler
you can run a little bit of atf with your oil, maybe 4 quarts oil- one quart atf. atf is a detergent and will clean your system out then do an oil change
