i have the RF TDZ-75/Bronco-75 ron francis harness. I am not getting a full 12volts to the fuel pump. i have remove the relay 4 pack and checking the wiring going to the proper relay. between what should be the positive and negative wires the 6.7 volts same as pump. the "negative" to the relay is a small brown wire that has on it R2 85 VIP 22SPL it disappears in the harness and i cannot find where it goes. the other three relays hava a commpn ground and a common hot wire feeding them. this one is different. i can temporary hook a ground wire to it and i get my 12 volts to the pump. I dont like short cutting the wiring and would like to know what this wire does so i can check its other connection
i will try and call Ron Francis outfit tomorrow but if anyone has run into this i would appreciate any information.
