Depends on how it looks? got pics? If you got a ton of rust then it will be more work. If all you need to do is scuff it for paint then use some 320 grit and a red pad. No need to take it down to bare metal, just scuff for a mechanical bond.
If your gona use liner then use 180 grit.
Blasting will probably run you $150, a sander and some paper will be about $50. up to you, and how it looks now.
