Sanding advise
NSG
Ive removed everything from inside the cab and am wanting to get it ready for paint/ bed liner. Would it be better to have someone sandblast it or is this something I could do myself with a sander from home depot?
bknbronco
North Metro, MN
Depends on how it looks? got pics? If you got a ton of rust then it will be more work. If all you need to do is scuff it for paint then use some 320 grit and a red pad. No need to take it down to bare metal, just scuff for a mechanical bond.
If your gona use liner then use 180 grit.
Blasting will probably run you $150, a sander and some paper will be about $50. up to you, and how it looks now.
rjrobin2002
Wire wheel on angle grinder works good for bare metal strip. Then wipe with a degreaser and epoxy prime for a perfect bond and rust prevention before liner. Or blast and epoxy prime. I have done both.
bknbronco
North Metro, MN
Still need to scuff with 320 and red pad before you paint. A whire wheel will only buff the metal and paint will never adhire well.
allenfahey
What kind of bedliner are you going to use? Also what condition is the bed in now? Linex or Rhino you can prep to bare metal and they will take it from there. With Raptor they recommend their etch primer either in spray can or spray gun on the bare metal prior to spraying it. It really depends on the current condition of the bed. Either way you don't paint it first but I would recommend painting the outside of the tub prior to bedliner.
Pat B
Take a look at Macro Stripping disc.....Work great with an angle grinder
Pat
