selector valve
chuck
Ingram, Texas
A customer sent these pictures to me because I couldn't figure out what he was talking about. He was told that the system was to prevent vaper lock. I have never seen this setup but would like to know more about it. If anyone has seen this system before they are most likely on this list so please shine a little light.
I have never seen that versiion of it. But I do know what it is all about.
The selector valve is a mechanical version of a 6 port selector valve for both supply and return.
That little brass/copper looking thingy by the accelerator pump is a controlled bypass of some sort. It returns some of the gas to the selector valve and back to the correct tank. The theory (a sound one too) is that by keeping gas flowing through the pump and lines it stays cooler. It doesn't have a chance to hot soak next to hot parts or soak in as much heat off the engine. Just like a return system on EFI.
AMC used a very similer version back in the 70's. If you go to the parts store and look at fuel filters you will find some with 3 nipples on them. That 3rd nipple is a return just like the version you show.
As for searching out that selector valve, I have 2 ideas. 1 would be to go to a modern electric 6 port, the other would be to look over AMC trucks for one with duel tanks.
JWMcCrary
That is the same valve that was on my 73 when I bought it. Also had the small line going to the fuel filter up by the carb. Scrapped all this within the first few weeks, I can't telll you anything about it other than that's what it had..
Dan's73
My '73 had the same lines running from the pump up to the carb, but the PO had replaced the selector valve with an electric unit. I figured that it was either for vapor lock or some sort of emissions setup. When I started tracing everything down, the diverter/bypass line by the accelerator pump dead-ended under the driver's seat; I assume that's where it would've connected to the stock selector switch to return fuel to the tanks. Regardless, I pulled it all and went with a single line from the pump to the carb without issue.
Now that we have had a couple people mention the '73, isn't that the one year that had a funky sending unit or gas tank, something like that? I wonder if it is because of this?
I'd never see one on a Bronco before, but I used to see them in the catalogs of fuel-selector valves.
Might still be available somewhere. Granger or similar supplier maybe?
That's a good thought Broncobowsher. '73 was a transition year for a lot of things. Maybe when they started offering the auto trans and power steering and stuff, they thought heat might be more of an issue in some areas. Or maybe it was even part of a high-altitude delivery option list?
It'll be fun to find out.
dgguidry
I had the six port valve on my 1973. I installed a new mechanical 3 port valve and plugged the emissions hoses. It runs great.
Boss Hugg
bringing an old thread back for one more thought...
I'm having trouble with my sending unit leaking around the electrical connector on the rear tank on my 73. it has the return line in it. Was looking at replacing it, but I wanted to see what everyone here was doing with this problem. Looks like it should be easy enough to delete the return, and I don't even have a good auxiliary tank, so I should even bypass the valve. (Maybe I'll ebay it??)
