Serpentine conversion parts list
Waverous
Aurora, CO
The alternator bracket needs to be notched to allow for the 3G. Mounting it on the drivers side will present problems with clearence of the hood and wiring to the battery. The mount bracket above the PS pump is for the AC compressor. Using a Sanden 508 converted to a self oiler works best for on board air and the serp setup mainly cause they already are serp compatable, small, and readily available (they are the choice of all these after market hot rod AC kits). As for the radiator, just move the lower radiator brackets forward so as to clear the brackets. Use an air chisel to remove the old mounts and 2 pieces of angel iron welded to the frame to move the frame forward.
Don70Sport
Ark/LA/Miss
Let me recind my earlier statement, the ps pump/bracket actually came off a 5.0 Crown Victoria, I imagine its much the same as the Licoln setup. The crown Vic did have the alternator mounted atop the ps pump, the 3g falls right into place on the bracket. It doesnt ride too high and with an induction style hood there are no clearence issues with the alternator. I"m gonna try a few different configurations with all the parts I've scrapped up the last week, I may/may not mount the 3g on the drivers side. I'm gonna make something work, and for under 100 bucks too. I will definatley have to re-do my alt wiring if I mount drivers side, not too much off a biggie. As per the radiator, I think you may have misunderstood me, its the fan itself in conflict with the ps pulley, not the radiator. We'll see........... if I pull this stunt off I'll post some pics.
eBronc
Austin, Texas
I don't see a problem running the 3G on top of the Lincoln P/S bracket, since the stock Lincoln alternator is in that position in the car. I just wasn't sure if the 3G would fit, since the Lincolns used the earlier smaller Mustang 5.0-type alternator.
The Lincoln 5.0 motor used a "quasi-serpentine" setup, which actually used TWO serpentine belts, one off the crank to run the smog pump and A/C compressor on the passengers side, and another one off the crank to run the water pump (standard rotation), the alternator, and the P/S pump on the driver's side.
My setup puts the Lincoln P/S pump, pulley, and bracket low on the driver's side (it's stock location) and the alternator up high next to the therostat housing on the passenger side. Stock 5.0 Mustang serpentine pullies fit the 5.0 aluminum reverse rotation pump, the crank (with a spacer), and the stock alternator. (Go back to the first page of this thread for links to pics).
I'll be running a 16" electric fan (from a Taurus SHO) behind my new BeCool radiator, so I won't have any mechanical fan fitmet issues.
More info:
http://www.mcguill.com/Bronco/tech.htm
