Excuse my long windedness. What I'm running is a big bearing 9 housing from an unknown year (bought the housing at a Wild Horses fall swap meet). At about 6900 miles on the odometer, I installed a Strange carrier assy., 4.56 gears, ARB dif., 35 spline axles and rear disc brakes from a 1978 Lincoln Mark VI. I'm running 35" tires as well. The axles on the Lincoln already used the set 20 bearings and that is what West Coat dif. recommended (new of course) for my setup. Initially all seemed fine. Recently I installed a Hydroboost setup from Wild Horses as my vacuum unit had failed (best thing I have done for my brakes). That is when I realized that intermittently (after cornering, L-R combination) that my next brake application had a deep pedal. The next brake application was fine. So, I thought I had some excess free play somewhere knocking the caliper pistons back. The front wheel bearings were fine however the rear axles had about .060" axial movement each. There is no noise from the axle bearings at this time. My current mileage is showing as 28k.
My housing end bearing pockets measure .707" and the retainer pockets measure about .197" The set 20 with seal measures .870" thick. That leaves me with a clamped bearing with over .030" extra axial room. So, I made some shims adding up to .051" and installed them behind the bearing cup. I reassembled and rechecked endplay to find I have .021". Just for grins I added another .010" and rechecked still .021". All endplay checks are made with dial indicator.
I purchased a new set20 bearing this morning and examined how endplay is controlled. The endplay is machined in as the inner and outer races contact ecah other in the od. recess for the seal. It appears to me the only thing the installer can do is make it worse by not making sure the pockets and retainers are in good shape. That's where I come in. I probably should weld on new bearing pockets. I'm gonna put the new bearing on a surface plate tomorrow to see what the as built endplay is. I'm also contemplating a floater kit for the rear. Thoughts?
