Set 20 preload and end play
TruFordBlu
I have a pair of set twenty axle bearings in a big bearing 9" housing. I am wondering if anyone has ever taken a new set 20 bearing and, without installing it on the axle, attempted to preload the bearing then check the endplay of the inner race? I'm fighting an endplay issue that appears to be from the bearing itself and not the entire assy. sliding in the end bearing pocket. Normally it wouldn't be an issue but I have rear disc brakes. Any information is appreciated.
Dave
Hammer6672
I had a problem like that with my wheel wood disc brake they kept leaking so I finally left there backing off and the end play problem went away and so did the leaking rear end dope
I know the tapered are supposed to be better, but I had better luck running the ball bearings.
phred
Earth
I had a similar issue but it I finally resolved that the bearing retainer was not pressed on far enough. Cut it off pressed on a new bearing and retainer and problem solved. How much endplay do you have????
Definitely post the measurements you're getting and what the rest of your setup is.
I can't imagine myself how you would check the end-play/preload without it installed on the axle, but I'm maybe not that intimately familiar with them either.
But are you also saying that you've installed your bearing and race into the housing and still have slop? If so, then that's very strange sounding.
Is this the first time Set-20's have been installed into this housing? If so, did you remove the old style axle seal from the housing?
Looking forward to more of this discussion. I always want to learn more about the different experiences people are having with them.
TruFordBlu
TruFordBlu
Excuse my long windedness. What I'm running is a big bearing 9 housing from an unknown year (bought the housing at a Wild Horses fall swap meet). At about 6900 miles on the odometer, I installed a Strange carrier assy., 4.56 gears, ARB dif., 35 spline axles and rear disc brakes from a 1978 Lincoln Mark VI. I'm running 35" tires as well. The axles on the Lincoln already used the set 20 bearings and that is what West Coat dif. recommended (new of course) for my setup. Initially all seemed fine. Recently I installed a Hydroboost setup from Wild Horses as my vacuum unit had failed (best thing I have done for my brakes). That is when I realized that intermittently (after cornering, L-R combination) that my next brake application had a deep pedal. The next brake application was fine. So, I thought I had some excess free play somewhere knocking the caliper pistons back. The front wheel bearings were fine however the rear axles had about .060" axial movement each. There is no noise from the axle bearings at this time. My current mileage is showing as 28k.
My housing end bearing pockets measure .707" and the retainer pockets measure about .197" The set 20 with seal measures .870" thick. That leaves me with a clamped bearing with over .030" extra axial room. So, I made some shims adding up to .051" and installed them behind the bearing cup. I reassembled and rechecked endplay to find I have .021". Just for grins I added another .010" and rechecked still .021". All endplay checks are made with dial indicator.
I purchased a new set20 bearing this morning and examined how endplay is controlled. The endplay is machined in as the inner and outer races contact ecah other in the od. recess for the seal. It appears to me the only thing the installer can do is make it worse by not making sure the pockets and retainers are in good shape. That's where I come in. I probably should weld on new bearing pockets. I'm gonna put the new bearing on a surface plate tomorrow to see what the as built endplay is. I'm also contemplating a floater kit for the rear. Thoughts?
ARB…
Possible that your axle shafts are too long on at least one side.
Seen it happen many times.
Then, again, if anything, I would think that would make bearing too tight when you torqued the plate down.
I didn’t read your whole post, but will go back and do it now. Just saw the ARB and wanted to comment while I was thinking about it.
Yeller
Rogers County Oklahoma
I have a drum brake rear with new ends and set 20’s. haven’t measured but it has some end play. Does not leak and the race and seal are tightly pressed together. New Timken bearings. I should have sucked it up and build a FF lol
TruFordBlu
TruFordBlu
Today I had a chance to measure the endplay on a brand new in the Timken box set 20 axle bearing. I got .013" of end play. I suppose that's about right for a semi float axle. Whenever I had a customer complain about an axle clunk during side-to-side movement from the rear of an 8.8" axle assy. I'd manufacture shims that would maintain .005"-.015 as Ford engineers recommended. It seemed to do the trick. The noise would occur when slow speed conditions, like entering a driveway at an angle, would occur.
My conclusion, I guess, is that my bearings are worn not worn out. But perhaps my axle housing ends are. Now it's up to me to decide what to weld on the ends of my housing. SF ends or FF ends.
PNW
TruFordBlu.... only one answer for ya.
FF :)
TruFordBlu
TruFordBlu
I will say that after getting the endplay down to .020" per side the brake feel is much better.
What did you do to get the .020? Use those new bearings?
Did they come with the basic/generic installation instructions giving you some specifications by any chance?
And how exactly did you get the .013" reading on the new ones? Is that installed on the axles and in the housing?
Glad it's feeling better for sure. Better brakes are just better!
TruFordBlu
TruFordBlu
The .020" was measured at the axle flange by dial indicator, with the old bearing installed and shims added behind the bearing cup to ensure the bearing and cone are completely sandwiched. The .013" number is the endplay of the new bearing inner race. That would also be the axle endplay if it were installed in the axle. The new bearing is set in a fixture, major half of the race towards the work bench, to hold it off of the work bench approx. .5". Then the minor half side of the outer race is clamped to the major half of outer race, (with the seal removed for visibility) in effect duplicating the clamping force generated on an installed bearing assy. This leaves the inner race free to be moved axially up and down and the endplay measured. A disc that fit the inner race was used from under the inner race as a surface to pry up and ensure the full travel was measured. I hope my description is good enough to create a visual as I did not take any pictures.
So, what my takeaway is, is my bearing pockets on my axles are a good .050" too deep.
Dave
PNW
This is so funny because as I was reading your description I was thinking it will be "easy" to figure out when I see his pics ... (that you didn't take!!) lol
TruFordBlu
TruFordBlu
This is one of those times that you get so involved at making sure you do it right everything else is out the window. That and the fact my cellphone still isn't my best friend.
Dave
TruFordBlu
TruFordBlu
A picture is worth a thousand words. Here's three thousand words, I hope. two with upper and lower dial readings and one showing dial mounting of the set 20 bearing assy. the puck under the inner race is pried up to get the free play reading.
Dave
PNW
If those were my posts those 3 pics would have saved probably 6 thousand words!! lol
This is what I thought you meant, appreciate the pics.
Between all the Set 20 issues and regular Ford 9" press on brgs shearing off axles I am pretty sure even on my 2WD Shorty build that I'll go FF. Need to look at what it does to my wheel hub. Can't look ugly
